VIN: WV1ZZZ7HZHH023737
Engine
Part #: 04L906056KA
Component: R4 2.0l TDI
Software version: 4047
ASAM/ODX identifier: EV_ECM20TDI03004L906056KA
Coding: 00114014432401090000 (hex)
Fault codes:
25796 Manufacturer-specific code
ABS
Part #: 7E0907379P
Component: ESC
Software version: 0133
ASAM/ODX identifier: EV_Brake1ESCCONTIVN75XGP2
Coding: 517E4098256484818A7C0279A48921E6790000 (hex)
[No fault codes]
Instrument cluster
Part #: 7E0920970S
Component: KOMBI
Software version: 1104
ASAM/ODX identifier: EV_Kombi_UDS_VDD_RM09
Coding: 450B010300 (hex)
[No fault codes]
Airbags
Part #: 7E0959655G
Component: VW10Airbag021
Software version: 0018
ASAM/ODX identifier: EV_AirbaVW10BPAVW12X
Coding: 000000000000000000000000000000003231 (hex)
[No fault codes]
Steering angle
Part #: 6R0959654
Component: LENKW.SENSOR
Software version: 0070
ASAM/ODX identifier: EV_LWSKLOVW25X
Coding: 01 (hex)
[No fault codes]
Parking/steering assist
Part #: 7E0919475T
Component: PARKHILFE 4K
Software version: 0212
ASAM/ODX identifier: EV_VW75XParkAssis4K
Coding: 10800A (hex)
[No fault codes]
Heater & air conditioning
Part #: 7E0907047AK
Component: Climatic-T5
Software version: 0708
ASAM/ODX identifier: EV_ClimaticT5
Coding: 0000000003 (hex)
[No fault codes]
Central electronics
Part #: 7E0937090B
Component: BCM PQ25 Max4
Software version: 0744
ASAM/ODX identifier: [none]
Coding: A0A4303A0A61343193284F747CEB9E740F84708F60CC6DE0320400220840 (hex)
Fault codes:
01134 Alarm Horn (H12)
CAN network gateway
Part #: 7E0909901
Component: GW-K-CAN TP20
Coding: 042305 (hex)
[No fault codes]
Immobilizer
Part #: 5K0953234
Component: IMMO
ASAM/ODX identifier: EV_Immo_UDS_VDD_RM09
Coding: 000000 (hex)
[No fault codes]
Battery regulator
Part #: 7E0907534
Component: Batt.regelung
Coding: 030B1A73 (hex)
Fault codes:
02252 Generator
Infotainment system
Part #: 1K8035150L
Component: MU-E-D-ER
Software version: 7067
ASAM/ODX identifier: EV_MUEnt4CGen2LGE
Coding: 065700003C00000041111101008000001F0000C60000010201 (hex)
[No fault codes]
Since buying your van in October, have you fully charged the battery? I’d start there first. It’s very common for a Stop/Start error to show with a battery that’s not at 80%I've recently hat a start stop error show on start up. I'm aware that wiring from the alternator could be the issue but I'm not 100% what location to check. I've attached the carista data below
ECU info obtained with Carista 6.3.2 for Android:
Engine
Part #: 04L906056KA
Fault codes:
ABS
Part #: 7E0907379P
Component: ESC
[No fault codes]
Instrument cluster
Part #: 7E0920970S
Component: KOMBI
[No fault codes]
Airbags
Part #: 7E0959655G
[No fault codes]
Steering angle
Part #: 6R0959654
Coding: 01 (hex)
[No fault codes]
Part #: 7E0919475T
[No fault codes]
Part #: 7E0907047AK
[No fault codes]
Central electronics
Part #: 7E0937090B
Fault codes:
CAN network gateway
Part #: 7E0909901
[No fault codes]
Immobilizer
Part #: 5K0953234
Component: IMMO
[No fault codes]
Battery regulator
Part #: 7E0907534
Fault codes:
02252 Generator
Infotainment system
Part #: 1K8035150L
[No fault codes]
No, I've not charged. I have had a couple of 4-5hour trips out in it though. I have a volt meter, what should the battery be sitting at voltage wise? 11.6v and above?Since buying your van in October, have you fully charged the battery? I’d start there first. It’s very common for a Stop/Start error to show with a battery that’s not at 80%
You have seen this/these?I've recently hat a start stop error show on start up. I'm aware that wiring from the alternator could be the issue but I'm not 100% what location to check. I've attached the carista data below
That looks promisingYou have seen this/these?
Error code 02252 - Battery Generator - error stop start on dash
hello i have a 2017 transporter t32 shuttle and when i got it, it had a stop/start error code come up on the dashboard i read the fault codes and it has 2 that keep comming back 01 Engine Control Module 1 U014000 Lost Communication with Body Control Module 5F Information Control Unit 1...www.t6forum.com
zero, it only becomes live when you turn on the ignition.What drain on the battery does Ghost have?
