I wonder if there is something going on with the imobiliser now the dash has been changed![]()
Your existing cluster is there so I wouldn't expect there to be any trust issues. I don't know how the Ghost works, but is there a coding issue?
@Deaky have you found a way around the old mfd making the odd station change or call dial? I'm trying to figure what VCDS can do to disable mfd media control, but still be retained for Digidash control. I guess its the big question..I get directions on mine like the old MFD but only using the head unit nav, not carplay nav.
Anyone wanting firmware I've got multivan for T5 1/T6 rev1 and rev2 boards. Working well.. pm me your email and which you need and I will invite you to access the relevant file on my GDrive.. for reference. Rev2 has the Android Auto and CarPlay logos on it.
Increased CANBUS data they say. Some bugs ironed out, vehicle T6 Multivan accessible, single colour on vehicle. Not so much else I can tell. Oh and mirror cast more stable.Is this new firmware compatible with all ICs and what are the new features?
I have an after market head unit so Bluetooth is not active on my MFD and I've not known it change radio station. I've not had chance to look at VCDS but it is something I need to do because the language setting is incorrect for me now. Not an issue with the dash but my AUX heater is all in German@Deaky have you found a way around the old mfd making the odd station change or call dial? I'm trying to figure what VCDS can do to disable mfd media control, but still be retained for Digidash control. I guess its the big question..
just leave it overnight, the bong will reset ;-)I have an Alpine Halo 11 with the Canbus interfeace.
I don't see the same telephony screen like I had on the MFD, or like you show above.
Righty, I take some of this back. Normally, the phone screen on the new dash shows 'Bluetooth Disconnected'. I don't get the same display as @Jan_B showing carrier and phone as we did on the old MFD. I think I made the first call in the van today and I got the normal call in progress details as we did with an MFD, see below.
But as to @Jan_B's original question, I can't select previous calls, access the phonebook etc, as you could do with the MFD. Not that I think I ever used it.
Still can't work out to use the wireless Android Auto that this new board is supposed to support.
Oh, and the bong has started at 20MPH....
yes, it seems they forget the vehicle mutilmedia has bluetooth and it shares this info to the dash. (the dash itself also has bluetooth but we dont use that). Sadyly im in the same boat as you although my display is in a random language (a bit like Deaky's aux heater controls)I asked the friendly technician about this problem, but I think he didn't understand me correctly.
He told me that the Bluetooth function is only for mirror link and not for phone function.
But something still seems to be happening in the background, otherwise I wouldn't be able to call the last contact.
Unfortunately I didn't get any further answers
Nope didn’t disappear even after 2 Nights … had to do the - OK Down thing multiple times and now its seems permanent gonejust leave it overnight, the bong will reset ;-)
Thanks Anthony.Anyone wanting firmware I've got multivan for T5 1/T6 rev1 and rev2 boards. Working well.. pm me your email and which you need and I will invite you to access the relevant file on my GDrive.. for reference. Rev2 has the Android Auto and CarPlay logos on it.
Download the fileThanks Anthony.
Please can you tell us: is it possible to roll back to current if something goes squiffy, and how does the file get to the clocks - what’s the process please? This appears to be different to previous thinking ie over the air updates.
Many thanks
Yeah. Not doing that. That means stripping the dash. The whole deal for me was over the air updates. I’m happy with the version I’ve got so will sit tight for a while.Download the file
Save it on a USB Stick ( Fat 32 Format ) do Not extract the File
Connect USB stick to the update USB Port
If all right done the Update will start automatically
According to the friendly Prelingcar Chinese Support man, there is No rollback to previous versions possible
You dont have a separate Update USB port beside the CarPlay Port ?Yeah. Not doing that. That means stripping the dash. The whole deal for me was over the air updates. I’m happy with the version I’ve got so will sit tight for a while.
But thank you sincerely for the explanation. Appreciated.
I hadn’t noticed that. I did my first update OTA, guess I was lucky to not have any issuesYou dont have a separate Update USB port beside the CarPlay Port ?
Btw : there was a very clear Warning not to update OTA written on the / my User manual
Yes, I do, bundled up and tucked away behind the dash as OTA was the advised update method.You dont have a separate Update USB port beside the CarPlay Port ?
Thanks for your update and the FilesI can get us rollback firmware if anything screwy goes on, I have hosted the files here, including a short tutorial - please read the readme! : FIRMWARE DOWNLOAD – Google Drive
P.S. Firmware can, of course, be rolled back - I would need to request that and then host it for you to USB. I have changed it many times to test new versions. These are the two I am sticking with for now - both support 5.1 & T6 - options depending on Rev1 & Rev2 boards. I now drop the USB cables down and access via the column adjust slot and fish around for them if needed.
That would be nice! I don't like the spinny driving vanAlso testing this morning.. snappy 'manufacturers' animated startup logo instead of spinny driving van. Will add to firmware collections and instructions if I love it which I think I already do.
