Cheers mate will take a look thank you. Need to get that halo 9 headunit in my van it's just sitting in a boxHey Fletch! Check out the links in my bio for new firmware and added bonus graphic.. might sort you out..
Will the items from this seller fit a 6.1 yet...?
Ah, well spotted. Once everything is assembled does it refuse the original bezel?
Edit - fook it. I'll wait until Antony has them as I have the hands-on skills of Abu Hamza, and I'm just up the road.
This can be changed in SettingMy RPM gauge is showing 8,000 RPM tops.
Did it todayHas anyone changed the boot logo to the original VW logo using Antony's file?
If I save the file to a USB stick and put it into the IC, nothing happens
Same hereThe fuel symbol next to the fuel gauge has a little arrow, this indicates which side of the vehicle the fuel filler is on. But even though I've selected RHD it points to the wrong side.
I noticed today that my MPG is displayed as ‘X mpg (UK)’, and I am still on the same revision as when you installed it Antony.Just going to throw this out there that I've been looking into the consumption reports and also agree it's affecting the tank mileage calculation. What I figured out.. by throwing the live data on the android auto display via Car Scanner app, and setting the consumption unit to Litres per hour I took a look at the idling consumption and noticed 0.7l per hr on the dash, 0.9l per hr on the ODB.. So I had a call with China and showed them this, I then asked which Gallon they are considering in the calculation, they seemed a little surprised to hear there is two versions of a Gallon. The UK version being swollen my 20% over the clearly calculated US version. So then our brains all start reverse calculating a 20% larger gallon throwing the maths out..
Anyway, in short the CEO and chief software engineer are aware now. I've said this is a big one and they need to pickup the option change when we do our unit set..US or UK Imperial and get it into future firmware pronto!. Let you know when it's done.. you're welcome
It will be stick compatibility.. there's no rhyme or reason to it sometimes. I have identical freebie sticks some good some badAny idea if the update is vender specific at all? As the FW update didn't work on mine but my firmware is reporting as app: Sport
Release some of the pressure from the screw back there. And just check that there is nothing going on in the opposite corner. They are quite sensitive to anything creating tortion forces when seated. Even deswarfing the cutout makes a difference. But bottom right like that likely to be screws need releasing slightly or top right has a cable trapped slightly, I have chased a few pressure spots out of mine in the dark before.Bit annoyed to see this on my drive this evening. I may have to take the dash apart again and see if there's any twisting pressure on the display. Otherwise it's a duff panel.
I don't remember seeing this at the start of the drive though :/
View attachment 272137View attachment 272138
Even check for swarf landing in the clips preventing a full seating.. had that..Thanks for that. I will slacken things up a little and enlarge my cut out a bit.
