Nice, well done that man, dare I ask, is it all finished?
Thanks @Victoria Alletson and @scotia
@scotia In the end I went for black out curtains from Kiravans. They are easy to fit and good quality and the rail system seems robust. I was wanting Vanshades but after talking to Pete the owner I realised it wasnt going to happen. 3 things were going against me - The fact I fitted a slider behind the drivers seat, the fact I have an LED light shelf from Evo Motion and the fact that I dont want to lose the partial window at the rear. To get past the slider a special pod needs to be used which put the pod 30mm out from flush at the top which would mean I couldnt fit my LED shelf. The way people get round this is by fitting a panel and losing the partial window at the rear and bonding the pod to the rear of the panel. Since I didnt want to lose that window this wasnt an option. So it was a choice between Vanshades or my LED shelf. Also Pete couldnt do a special pod for the partial window for me either so if I chose the Vanshades route I still would have a pod on that rear partial window, so in the end the best option for me was to go with curtains. The £600 saving is a nice bonusand will be getting spent on a dash cam kit
I didn't have one in my old van and I like the extra space. Everything in my van is revolving around space saving. I picked a LWB, tailgate, removable compressor on the fridge, battery stored in the rear cupboard etc. The main reason for not having a sink was not ever really using it, and having a carry on washing basket.Andy, what's the reason you don't want a sink? Although small I found it handy for watching up cups and plates etc when we had a hire camper
I see these converted campers with a sink and double hob in a swb, they have no usable worktop and the cupboards are filled with water containers and gas bottles, poorly designed.
I think I will have a sink, and a fresh water container, then plumb the waste water straight out the van.
I'll be drilling a hole through my floor any day now to plumb away the grey water. I'm also planning on an underslung LPG tank. That will help free up some cupboard space
@xpfloyd I did a similar thing with the grey water from the sink. As I had dual doors I put a hole through the top of the step to the outside. There was a grommet in the centre underneath through the body, don’t know what is was there for but it fitted the hose perfectly through it and the protective panel under that. My problem being a 4motion and beefed up suspension and under body protection, there is no room under there for any tanks, I was originally going to put the water under there but the exhaust that is underneath the drivers side stopped that.I'll be drilling a hole through my floor any day now to plumb away the grey water. I'm also planning on an underslung LPG tank. That will help free up some cupboard space
Stick twin spares on hatch, water tanks where the spare sits...@xpfloyd I did a similar thing with the grey water from the sink. As I had dual doors I put a hole through the top of the step to the outside. There was a grommet in the centre underneath through the body, don’t know what is was there for but it fitted the hose perfectly through it and the protective panel under that. My problem being a 4motion and beefed up suspension and under body protection, there is no room under there for any tanks, I was originally going to put the water under there but the exhaust that is underneath the drivers side stopped that.
