Today i ran the 16mm2 cable in conduit thought the the grommet above the battery, couldn't crimp the lugs, as my cable lug clamp is broken
, ill have to go and get another one next week.
I also ran a 1.13m2 twin cable, one with the 16mm2 feed and the other at the fuse for the ignition live connection, i then ran the cables through a sheath along the existing cable, up the D Piller and chased through to the back through the roof line.
Ill drop it down once i remove the quarter panel.
I'll also be pulling the 1.13mm2 cable back from the battery area back to the fuse area, as 1.13mm2 is only good for a signal, and not for a main battery feed, for some reason, i had it in my head i was using the thicker twin cable
, that i have.
I made a small insulation flooring sheet with the 4mm reflective closed cell foam and fitted it over the sound deadening and taped it down, it personally can't see it doing much, as that rubber flooring is quite dense, but its light and i have half a roll left.
I then refitted the rubber floor, I'm glad i didn't go nuts on insulating the wheel arches, its quite a tight fit with that rubber floor.
I'll attack putting the dash trims back on Monday as well as installing some sound deadener on the entry step before i refit the D Piller trims and entry trims.
If anyone is curious, the rubber caps on the seat mounting bolts are just 10mm rubber feet screwed on for safety while working in the bare cab.
