Yes, they are presets - unfortunately every user can feed those in so can't always trust them. The ones marked "T6:..." seem to be my contributionbut i have no idea what these do - are these presets? The one with led headlights and non-led rears (my setup now) is noted as barn door (i have tailgate).
So if I click on this one it does all the byte 18 mods then? And then for the other ones I can just go through them as noted on the list..Yes, they are presets - unfortunately every user can feed those in so can't always trust them. The ones marked "T6:..." seem to be my contribution
Of course you can just tick the boxes to create your own coding.
The one with LED headlights + non-LED rears should work for you, too (regardless of tailgate or barn doors).
Yes, byte 21 bit 0 = "1" - the text should show then "Led"count from the top being bit zero?
For Byte 21 bit 0 - on my list i have to put it to 1 so on, but i have this as a description.. seems odd?
Correct.So if I click on this one it does all the byte 18 mods then? And then for the other ones I can just go through them as noted on the list..
Well, a kind of tool for that is here "T6_09_BCM_Coding_Decoder" as an attachment.Is there anyway to develop what these presets are? I just want to check through it for my understanding..!
I'll check this later...my full long coding is this:
62A0393A0A21209201284F742CEB8ED48FA0710F60C66D60320400230800
Yes - it's a bit clumsy in OBDeleven, but doable yes.If I accept the change can I revert back to my backup by typing it in to the long code?
Correct.
VCDS codes list
Posting this here as I believe it contains codes previously undocumented on the forum. It comes from the the OBDeleven forum, with extra functions added to the list by the poster Oberon. I'm posting as is and take no responsibility for the accuracy of the data. Central electrics control unit...www.t6forum.com
I'll check this later...When done please post again your "final" coding.
