Confused and scratching my head here!?
I swapped modules as
@Pauly suggested which then gave me the error code originally from the Left over to Right. Thought that was problem solved, replacement module needed, didn't swap them back as right hand side (offside) is easy enough to change in situ.
Purchased a module, type (A), cleared codes with VCDS, run through a light test and a VCDS output test, all seemed to work ok.
Was out in the van at 5 this morning and the fault light appeared again. Got home plugged in VCDS and I'm getting a fault warning on the LEFT??
Question; Does left on VcDS mean nearside or offside?
So I'm really scratching my head as to where the fault lies.
I should note that all this seems to have started since i upgraded my starter battery a couple of weeks prior (Varta 80ah), all coded correctly, not sure if that would have any effect though?
Have also installed lower grille Drls, but they were running for months before this happened and have disconnected them with same fault appearing.
Have checked for loose connections, can see anything obvious.
error code below, not bothered about the high beam faults as i know from
@Robert i need vag can to sort that one.
Any suggestions would be appreciated, thank you
Update: Have cleared codes and tried to get the bulb warning light to come up while sitting on the drive, can't do it, no fault codes nothing.
Output tests read OK except for High Beam.
Starting to think the error code i got when i swapped the modules might have been because i disconnected the lights...i'm old i can't remember!
Am considering there could be a faulty wire (earth) possibly and the motion of the van on the road is causing movement, thus triggering a fault but only when the headlights are on?
Stumped!
