Here's my autoscan.
As above, I have a bulb-out light showing on the dash, and (when set to Auto) the dipped LEDs kept turning off when I'd have expected them to remain on given the dusky lighting. Bizarrely I actually think they turned on whilst sat in traffic when I clicked the heater on to 1!
For reference, my original 09 coding was: B8FE793A0A61341193284F6476AF9E740D8070F160CC6DF03204003F0800
2015 Eu5 140PS Highline P/Van with barn-doors that were converted to a tailgate (with two cables to BCM Pin10 & Pin23 black plug?), LED numberplate and tail lights. LED headlights replace H4's.
Rich (BB code):
Thursday,05,October,2023,21:38:44:26777
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0 (x64) HEX-V2 CB: 0.4639.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WV1ZZZ7HZGH04ADAM License Plate: ADS_ESSEX
Mileage: 82940km-51536mi Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 55 5F 61 0B
VIN: WV1ZZZ7HZGH04ADAM Mileage: 82940km-51536miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
s09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (J623-CAAC) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 GQ HW: 03L 907 309 L
Component: R4 2,0L EDC H38 8440
Revision: 22H38--- Serial number: 00000000000000 CVN: D2CF8DB6
Coding: 01194012232401080000
Shop #: WSC 02734 790 00000
ASAM Dataset: EV_ECM20TDI01103L906019GQ 003006
ROD: EV_ECM20TDI01103L906019FH_003.rod
VCID: 005875B80A858A9A0FB-8054
VINID: 9E606AAAA1D8A976001041452069595186
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes (J104) Labels: 7E0-907-37x-MK100ESC.clb
Part No SW: 7E0 907 379 P HW: 7E0 907 379 M
Component: ESC H05 0132
Revision: 00000000 Serial number: 42535000001716
Coding: 517E4098256684828A7A027BA48A21D3390000
Shop #: WSC 02739 790 50316
ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 3FDAB64437FB3562361-806A
1 Fault Found:
4197 - Rear Left Wheel Speed Sensor
C101C 14 [137] - Open or Short to Ground
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 170
Mileage: 82946 km
Date: 2023.10.05
Time: 21:09:25
Address 04: Steering Angle (G085) Labels:* 6R0-959-654.clb
Part No SW: 6R0 959 654 HW: 6R0 959 654
Component: LENKW.SENSOR H07 0070
Serial number: 20071504652357
Coding: 01
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA40B407071FC6A7D7-802A
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 7E0 907 047 T HW: 7E0 907 047 T
Component: Climatic-T5 H22 0607
Revision: 00001002
Coding: 0000000003
Shop #: WSC 02737 790 50316
ASAM Dataset: EV_ClimaticT5 A01003
ROD: EV_ClimaT5Basis.rod
VCID: 3B22C25423E329421A9-806E
Address 09: Cent. Elect. (J519) Labels:. 7E0-937-BCM-V1.clb
Part No SW: 7E0 937 090 HW: 7E0 937 090
Component: BCM PQ25 Max4 H80 0736
Revision: B9080001 Serial number: 0771 251150786
Coding: B8F4F93A4A61341193284F2426EA9670CD8073F160C979D03204003F0800
Shop #: WSC 00592 210 00001
VCID: 68884D18027552DAA7B-803C
Subsystem 1 - Part No: 5K7 955 559 B Labels: 5K7-955-559.CLB
Component: RLS 230915 03 37 0059
Coding: 0228EE
Subsystem 2 - Part No SW: 7E0 959 801 K HW: 7E0 959 801 K Labels: 7E0-959-80X-V2.CLB
Component: J386__TSG_FT 003 8654
Serial number: KU0KU004091552472012
Coding: 1400B0
Subsystem 3 - Part No SW: 7E0 959 802 K HW: 7E0 959 802 K Labels: 7E0-959-80X-V2.CLB
Component: J387__TSG_BT 003 8654
Serial number: KU0KU027081552395697
Coding: 0400A0
Subsystem 4 - Part No: 7E1 951 172
Component: DWA-Sensor 00 001 0104
Coding: 000000
Subsystem 5 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Coding: 000000
Subsystem 6 - Part No: 7E1 951 172
Coding: 000000
Subsystem 7 - Part No SW: 5G0 959 442 H HW: 5G0 959 442 H
Component: E221__MFL-DC1 H17 0103
Serial number: 29150001847080075382
Coding: A4FFFF
2 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 210
Mileage: 82946 km
Time Indication: 0
Date: 2018.02.25
Time: 21:16:14
00979 - Lamp for Low Beam; Right (M31)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 210
Mileage: 82946 km
Time Indication: 0
Date: 2018.02.25
Time: 21:15:36
Address 10: Park/Steer Assist (J446) Labels:| 7E0-919-475.clb
Part No SW: 7E0 919 475 M HW: 1Q0 919 475
Component: PARKHILFE 4K H03 0205
Revision: -------- Serial number: 32931520205484
Coding: 10800A
ASAM Dataset: EV_VW75XParkAssis4K 001008
ROD: EV_VW75XParkAssis4K_001.rod
VCID: 3C20C14826ED2E7A133-8068
Address 15: Airbags (J234) Labels:| 5K0-959-655.clb
Part No SW: 7E0 959 655 D HW: 7E0 959 655 D
Component: VW10Airbag00J 008 0016
Revision: -------- Serial number: 003PH00125V+ Dataset Number: 7E0003V____ 0737
Coding: 00000000000000000000000000000000304A
Shop #: WSC 02734 790 50316
ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 372ADE641FCB0D22FE1-8062
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb-SRI1
Part No SW: 7E0 920 970 L HW: 7E0 920 970 L
Component: KOMBI H05 1008
Coding: 7709010100
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
VCID: 3332EA740BB3E102C29-8066
Address 19: CAN Gateway (J533) Labels:. 7E0-909-901.clb
Part No SW: 7E0 909 901 HW: 7E0 937 090
Component: GW-K-CAN TP20 H80 0736
Revision: B9080001
Coding: 042307
Address 25: Immobilizer (J334) Labels:| 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H05 1008
Serial number:
Coding: 000000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
VCID: 6A8C37101CF960CAB1F-803E
Address 55: Headlight Range (J431) Labels:. 6R0-907-357.clb
Part No SW: 6R0 907 357 HW: 6R0 907 357
Component: LWR-ECU H02 0070
Revision: -------- Serial number: --------------
Coding: 0312000001000000
Shop #: WSC 20200 993 28888
ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
ROD: EV_HeadlRegulVWLWRPt_VW25.rod
VCID: 77AA1E645F4BCD223E1-8022
2 Faults Found:
5256725 - Rear Vehicle Height/Level Sensor
C114E 15 [137] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 170
Mileage: 82946 km
Date: 2023.10.05
Time: 21:09:24
13705985 - Databus
U1123 00 [137] - Received Error Message
[Fehlerwert im Signal BR3_Rad_kmh_HL]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 170
Mileage: 82946 km
Date: 2023.10.05
Time: 21:09:25
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD2.clb
Part No SW: 5C0 035 680 C HW: 5C0 035 680 C
Component: MU-S-ND-ER H22 0245
Serial number: VWZAZ2R8864707 Dataset Number: 5K7CV1v____ 0001
Coding: 065700013C00000011111101008808001F0107C6002001004F
ASAM Dataset: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 211E103CA14F6392205-8074
Data carrier:
Subsystem 1 - Part No SW: 5NA 919 866 CK HW: -----------
Component: ECE AS 2023 --- 1910
Serial number: --------------------
4 Faults Found:
0517 - Front Right Bass Speaker
B1062 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 2: Unterbrechung (DC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 170
Mileage: 82946 km
Date: 2023.10.05
Time: 21:09:24
Voltage terminal 30: 12.3 V
0518 - Front Right Treble Speaker
B1064 13 [009] - Open Circuit
[Hochtonlautsprecher Kanal 2: Unterbrechung (AC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 170
Mileage: 82946 km
Date: 2023.10.05
Time: 21:09:24
0522 - Front Left Bass Speaker
B105F 13 [009] - Open Circuit
[Tieftonlautsprecher Kanal 3: Unterbrechung (DC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 170
Mileage: 82946 km
Date: 2023.10.05
Time: 21:09:24
0523 - Front Left Treble Speaker
B1061 13 [009] - Open Circuit
[Hochtonlautsprecher Kanal 3: Unterbrechung (AC-Diagnose)]
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 170
Mileage: 82946 km
Date: 2023.10.05
Time: 21:09:24
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H80 0736
Coding: 030B1A73
Shop #: WSC 02739 790 00000
Subsystem 1 - Part No SW: 7E0 915 181 G HW: 7E0 915 181 G
Component: J367-BDM H08 0223
Serial number: 52237I02461261550806
End----------(Elapsed Time: 01:54, VBatt start/end: 12.3V/12.3V)-----------
For info, I have Eton speakers and a Kenwood amp installed, so that may give rise to the 5F fault codes. And I've posted on another thread about the ABS and TPMS faults.. I hit a pothole at the rear nearside recently and wonder if that is related.
Cheers,
Ads
