@mmi I’ve just changed this byte as suggested and all lights work perfectly. On a drive, they all behave as they should. I still have the ‘bulb error’ warning lamp on the dash with DTC’s showing ‘open or short to plus’ errors for both low beams.
Ok, good news is the lights work. Just need to resolve the dash warning.
2) if not perfect could try changing also byte 29 from "00" to "60"
2) Changing byte 29 from '00' to '60' has now left me with an exclamation mark in place of the odometer reading and a BCM error - i'm going to change the coding back and see if that solves it.
Apologies for wrong information. Just realised the slight difference between EU5 and EU6 engines and codings re MFSW/CC
***** Could you please try again by changing byte 29 from "00" to "20"
don’t know what the bulb error lamp is on for.
Just to clarify? Do you mean there are no faults in 09-Central electrics, or in 55-Headlight Range??
Or there are the???
which are actually the cause for the dash warning light, no???
There are a couple of undocumented/strange differences in your coding, e.g:
  • Byte 2 bit 7 =1, which normally is 0
  • Byte 12 bit 1=1 - "Daytime Running Light (DRL) adjustable (Manually AND/OR Instrument Cluster)" which AFAIK does not work on T6, normally is 0
Not sure if they are related but I'd suggest to turn them to "normal" unless you know their effect.
Or there are the???
I've changed the coding as you advise - I've not driven anywhere but lights illuminate as they should.
I've done a scan before and after so you can see; yes, there were and are still faults - 09-Central Electrics, with dipped bulb and the 55-Headlight Range, which I presume is me using the HRCM without the C revision?
Would this incorrect HRCM cause the bulb error warning with the dipped beam?
Code:
Saturday,07,October,2023,08:49:41:26777
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 23.3.1.0 (x64)  HEX-V2 CB: 0.4639.4
Data version: 20230421 DS346.2
www.Ross-Tech.com
VIN: WV1ZZZ7HZGH04ADAM   License Plate: HEADLAMPS_WORKING
Mileage: 82950km-51542mi   Repair Order:
Chassis Type: 7H-VN75 (7E0)
Scan: 01 03 04 08 09 10 15 17 19 25 55 5F 61 0B
VIN: WV1ZZZ7HZGH04ADAM   Mileage: 82950km-51542miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
5F-Information Electr. -- Status: Malfunction 0010
61-Battery Regul. -- Status: OK 0000
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 019 GQ    HW: 03L 907 309 L
   Component: R4 2,0L EDC   H38 8440
   Revision: 22H38---    Serial number: 00000000000000 CVN: D2CF8DB6
   Coding: 01194012232401080000
   Shop #: WSC 02734 790 00000
   ASAM Dataset: EV_ECM20TDI01103L906019GQ 003006
   ROD: EV_ECM20TDI01103L906019FH_003.rod
   VCID: 005875B80A858A9A0FB-8054
   VINID: 9E606AAAA1D8A976001041452069595186
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes (J104)       Labels: 7E0-907-37x-MK100ESC.clb
   Part No SW: 7E0 907 379 P    HW: 7E0 907 379 M
   Component: ESC           H05 0132
   Revision: 00000000    Serial number: 42535000001716
   Coding: 517E4098256684828A7A027BA48A21D3390000
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_Brake1ESCCONTIVN75XGP2 011001
   ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
   VCID: 3FDAB64437FB3562361-806A
1 Fault Found:
4197 - Rear Left Wheel Speed Sensor
          C101C 14 [137] - Open or Short to Ground
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82956 km
                    Date: 2023.10.07
                    Time: 06:53:41
Address 04: Steering Angle (G085)       Labels:* 6R0-959-654.clb
   Part No SW: 6R0 959 654     HW: 6R0 959 654
   Component: LENKW.SENSOR  H07 0070
   Serial number: 20071504652357
   Coding: 01
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_LWSKLOVW25X 005001
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA40B407071FC6A7D7-802A
Address 08: Auto HVAC (J301)       Labels:| 7E5-907-047.clb
   Part No SW: 7E0 907 047 T    HW: 7E0 907 047 T
   Component: Climatic-T5   H22 0607
   Revision: 00001002
   Coding: 0000000003
   Shop #: WSC 02737 790 50316
   ASAM Dataset: EV_ClimaticT5 A01003
   ROD: EV_ClimaT5Basis.rod
   VCID: 3B22C25423E329421A9-806E
Address 09: Cent. Elect. (J519)       Labels:. 7E0-937-BCM-V1.clb
   Part No SW: 7E0 937 090     HW: 7E0 937 090
   Component: BCM PQ25 Max4 H80 0736
   Revision: B9080001    Serial number: 0771 251150786
   Coding: B8F4F93A4A61341193284F2426EA9670C08073F160C979D03204003F0800
   Shop #: WSC 00592 210 00001
   VCID: 68884D18027552DAA7B-803C
   Subsystem 1 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 230915 03  37  0059
   Coding: 0228EE
   Subsystem 2 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8654
   Serial number: KU0KU004091552472012
   Coding: 1400B0
   Subsystem 3 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8654
   Serial number: KU0KU027081552395697
   Coding: 0400A0
   Subsystem 4 - Part No: 7E1 951 172
   Component: DWA-Sensor 00  001 0104
   Coding: 000000
   Subsystem 5 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
   Coding: 000000
   Subsystem 6 - Part No: 7E1 951 172
   Coding: 000000
   Subsystem 7 - Part No SW: 5G0 959 442 H    HW: 5G0 959 442 H
   Component: E221__MFL-DC1  H17 0103
   Serial number: 29150001847080075382
   Coding: A4FFFF
2 Faults Found:
00978 - Lamp for Low Beam; Left (M29)
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82957 km
                    Time Indication: 0
                    Date: 2018.02.27
                    Time: 08:48:46
00979 - Lamp for Low Beam; Right (M31)
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 114
                    Reset counter: 172
                    Mileage: 82956 km
                    Time Indication: 0
                    Date: 2018.02.27
                    Time: 06:53:43
Address 10: Park/Steer Assist (J446)       Labels:| 7E0-919-475.clb
   Part No SW: 7E0 919 475 M    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0205
   Revision: --------    Serial number: 32931520205484
   Coding: 10800A
   ASAM Dataset: EV_VW75XParkAssis4K 001008
   ROD: EV_VW75XParkAssis4K_001.rod
   VCID: 3C20C14826ED2E7A133-8068
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 7E0 959 655 D    HW: 7E0 959 655 D
   Component: VW10Airbag00J 008 0016
   Revision: --------    Serial number: 003PH00125V+ Dataset Number: 7E0003V____ 0737
   Coding: 00000000000000000000000000000000304A
   Shop #: WSC 02734 790 50316
   ASAM Dataset: EV_AirbaVW10BPAVW12X 001028
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 372ADE641FCB0D22FE1-8062
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 7E0 920 970 L    HW: 7E0 920 970 L
   Component: KOMBI         H05 1008
   Coding: 7709010100
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05730
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
   VCID: 3332EA740BB3E102C29-8066
Address 19: CAN Gateway (J533)       Labels:. 7E0-909-901.clb
   Part No SW: 7E0 909 901     HW: 7E0 937 090
   Component: GW-K-CAN TP20 H80 0736
   Revision: B9080001
   Coding: 042307
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H05 1008
   Serial number:
   Coding: 000000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03710
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6A8C37101CF960CAB1F-803E
Address 55: Headlight Range (J431)       Labels:. 6R0-907-357.clb
   Part No SW: 6R0 907 357     HW: 6R0 907 357
   Component: LWR-ECU       H02 0070
   Revision: --------    Serial number: --------------
   Coding: 0312000001000000
   Shop #: WSC 20200 993 28888
   ASAM Dataset: EV_HeadlRegulVWLWRPt 001004
   ROD: EV_HeadlRegulVWLWRPt_VW25.rod
   VCID: 77AA1E645F4BCD223E1-8022
1 Fault Found:
13705985 - Databus
          U1123 00 [137] - Received Error Message
          [Fehlerwert im Signal BR3_Rad_kmh_HL]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 3
                    Reset counter: 172
                    Mileage: 82956 km
                    Date: 2023.10.07
                    Time: 06:53:42
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-STD2.clb
   Part No SW: 5C0 035 680 C    HW: 5C0 035 680 C
   Component: MU-S-ND-ER    H22 0245
   Serial number: VWZAZ2R8864707 Dataset Number: 5K7CV1v____ 0001
   Coding: 065700013C00000011111101008808001F0107C6002001004F
   ASAM Dataset: EV_MUStd4CTSAT 001022
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 211E103CA14F6392205-8074
   Data carrier:
   Subsystem 1 - Part No SW: 5NA 919 866 CK    HW: -----------
   Component: ECE AS 2023  --- 1910
   Serial number: --------------------
5 Faults Found:
1556 - Internal Control Module Memory Check Sum Error
          B2000 87 [009] - Missing Message
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82956 km
                    Date: 2023.10.07
                    Time: 06:48:36
                    Voltage terminal 30: 12.5 V
                    System_Software_Error-SW_Status_Consistency: 04 01 01
                    System_Software_Error-SW_Status_Device: o
0517 - Front Right Bass Speaker
          B1062 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 2: Unterbrechung (DC-Diagnose)]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82956 km
                    Date: 2023.10.07
                    Time: 06:48:32
0518 - Front Right Treble Speaker
          B1064 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 2: Unterbrechung (AC-Diagnose)]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82956 km
                    Date: 2023.10.07
                    Time: 06:48:32
0522 - Front Left Bass Speaker
          B105F 13 [009] - Open Circuit
          [Tieftonlautsprecher Kanal 3: Unterbrechung (DC-Diagnose)]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82956 km
                    Date: 2023.10.07
                    Time: 06:48:32
0523 - Front Left Treble Speaker
          B1061 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 3: Unterbrechung (AC-Diagnose)]
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82956 km
                    Date: 2023.10.07
                    Time: 06:48:32
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7E0 907 534     HW: 7E0 937 090
   Component: Batt.regelung H80 0736
   Coding: 030B1A73
   Shop #: WSC 02739 790 00000
   Subsystem 1 - Part No SW: 7E0 915 181 G    HW: 7E0 915 181 G
   Component: J367-BDM  H08 0223
   Serial number: 52237I02461261550806
End----------(Elapsed Time: 01:51, VBatt start/end: 12.4V/12.5V)-----------
Address 09,7E0 937 090 ,recoded (Long Coding),from,B8F4F93A4A61341193284F2426EA9670C08073F160C979D03204003F0800,to,B8F4F93A4A61341193284F2424EA9670C08073F160C979D03204003F0820,(00592/210/00001),
Readiness: 0 0 0 0 1
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82957 km
                    Date: 2023.10.07
                    Time: 08:55:00
   Coding: 01
   Revision: 00001002
   Coding: 0000000003
   Coding: B8F4F93A4A61341193284F2424EA9670C08073F160C979D03204003F0820
   Coding: 0228EE
   Coding: 1400B0
   Coding: 0400A0
   Coding: 000000
   Coding: 000000
   Coding: 000000
   Coding: A4FFFF
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82957 km
                    Time Indication: 0
                    Date: 2018.02.27
                    Time: 08:55:15
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82957 km
                    Time Indication: 0
                    Date: 2018.02.27
                    Time: 08:55:15
   Coding: 10800A
   Coding: 7709010100
   Revision: B9080001
   Coding: 042307
   Serial number:
   Coding: 000000
1 Fault Found:
13705985 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 2
                    Reset counter: 172
                    Mileage: 82957 km
                    Date: 2023.10.07
                    Time: 08:55:00
   Data carrier:
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82957 km
                    Date: 2023.10.07
                    Time: 08:54:59
                    Voltage terminal 30: 12.3 V
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82957 km
                    Date: 2023.10.07
                    Time: 08:54:59
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82957 km
                    Date: 2023.10.07
                    Time: 08:54:59
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82957 km
                    Date: 2023.10.07
                    Time: 08:54:59
   Coding: 030B1A73
End----------(Elapsed Time: 01:53, VBatt start/end: 12.4V/12.4V)-----------
Reactions: mmi
1 Fault Found: 13705985 - Databus U1123 00 [137] - Received Error Message [Fehlerwert im Signal BR3_Rad_kmh_HL] MIL ON - Confirmed - Tested Since Memory Clear
I guess it could be the 55 fault which turns the warning light on (MIL ON in the fault log) - because currently the headlight warning manifest should be disabled (but it doesn't affect to fault codes in the background).
A bit uncharted to me but what about disabling the 55-Headlight regulation from Gateway installation list just to see if that extinguishes the dash bulb warning (trying to verify the actual source of the dash light) (yes, will create other faults into log).
At the moment just a reference to somewhat similar behaviour earlier
Also what you have in the adaptations - channel 55?
Perhaps you could post also the BCM adaptation map?
Perhaps needs to be documented also here - originally was a by-product in [Guide] How To Retrofit MFSW And Cruise Control To T6 Eu6 2019 Startline - Also Hacking DSG Paddles For CCS
On my T6 (factory LED headlights, MFSW, EU6) manipulating byte 29 bit 5 from normal=1 to "0" triggers the following faults and dash bulb warning soon after setting off - although the light are just fine.
Code:
00978 - Lamp for Low Beam; Left (M29) -  010 - Open or Short to Plus - Intermittent[/INDENT][/INDENT]
[INDENT]00979 - Lamp for Low Beam; Right (M31) -  010 - Open or Short to Plus[/INDENT]
[INDENT]01495 - Bulb for High-Beams; Left (M30) -  007 - Short to Ground - Intermittent
I've removed 55 from the 19-CAN Gateway installation list, keyed off and then back on again before running a new scan; a fault shows in both 19:
Code:
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 - -
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 82957 km
                    Time Indication: 0
                    Date: 2018.02.27
                    Time: 10:30:08
and in 55:
Code:
                             Address 09: Cent. Elect.       Labels: 7E0-937-BCM-V1.clb
Control Module Part Number: 7E0 937 090     HW: 7E0 937 090
  Component and/or Version: BCM PQ25 Max4 H80 0736
           Software Coding: B8F4F93A4A61341193284F2424EA9670C08073F160C979D03204003F0820
            Work Shop Code: WSC 00592 210 00001
2 Faults Found:
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 212
                    Mileage: 82957 km
                    Time Indication: 0
                    Date: 2018.02.27
                    Time: 10:30:08
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82957 km
                    Time Indication: 0
                    Date: 2018.02.27
                    Time: 10:30:08
Door is ajar (I'm sure I read that or the bonnet have to be open) but I haven't done a battery disconect nor lock up and let it rest - let me know if this change requires that.
In 09-Central Electrics, Adaption, Channel 55-Lamp Diagnostics I had a Stored Value-1 and a New Value-1 showing - as per your link, I changed that New Value to 0 and it took it. After keying off and back on again, I turned the headlights on manually at the knob and the bulb error came back. On turning headlights off, clearing DTC's, keying off, keying on and manually turning headlights back on, the buld error lamp returned. A scan showed only one error in 09 this time: 00979 - Lamp for Low Beam; Right (M31).
Looking in Adaptions, Channel 55 was still showing Stored value-0.
Like @ched did here, I then changed 09 Adaptions Channel-55 back to Value 1, but the bulb error remains illuminated on the dash.
After he posted this, you subsequently mentioned a battery disconnect to force the BCM to accept the coding and adaption changes. I will try that next.
Code:
00978 - Lamp for Low Beam; Left (M29) -  010 - Open or Short to Plus - Intermittent[/INDENT][/INDENT][/INDENT]
[INDENT][INDENT]00979 - Lamp for Low Beam; Right (M31) -  010 - Open or Short to Plus[/INDENT][/INDENT]
[INDENT][INDENT]01495 - Bulb for High-Beams; Left (M30) -  007 - Short to Ground - Intermittent
I have just checked and 09 shows byte 29 bit 5 at 1 already.
Going from 09 byte 29 bit 20 to hex 40 did not extinguish the bulb error light on the dash, nor did changing it to 60 - but hex 60 did bring a new error, along with the other dipped beam fault returning:
Code:
           Software Coding: B8F4F93A4A61341193284F2424EA9670C08073F160C979D03204003F0840
3 Faults Found:
            000 - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 82957 km
                    Time Indication: 0
                    Date: 2018.02.27
                    Time: 11:04:21
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 172
                    Mileage: 82957 km
                    Time Indication: 0
                    Date: 2018.02.27
                    Time: 11:05:03
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82957 km
                    Time Indication: 0
                    Date: 2018.02.27
                    Time: 11:04:22
On running a new scan, my BCM now shows a fault: 4717 - BCM no comms - so I'll change back to 20.
EDIT: on checking the 09 coding, hex 60 appears to have not taken - or reverted - as it shows as being 40 again. I've changed it to 60 and the BCM error still shows, their being an exclamation mark where the odo reading is on the MFD.
EDIT: Annoyingly, the hex 60 adaption clears the bulb error light on the dash!
EDIT: I'm back to my last good known coding - byte 29 hex 20 - and the BCM fault has gone.
The bulb error light comes back when I switch on the headlights at the knob, still; 00979 - Lamp for Low Beam; Right (M31).
Here is my BCM (09) adaptation map (engine running this time):
I don't have Excel on this laptop so can't open it to check its readable!
and a full scan:
Code:
Saturday,07,October,2023,12:11:45:26777
www.Ross-Tech.com
VIN: WV1ZZZ7HZGH04ADAM   License Plate: POST-1226
19-CAN Gateway -- Status: Malfunction 0010
55-Headlight Range -- Status: Not registered 0011
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82957 km
                    Date: 2023.10.07
                    Time: 11:39:58
   Coding: 01
   Revision: 00001002
   Coding: 0000000003
   Coding: 0228EE
   Coding: 1400B0
   Coding: 0400A0
   Coding: 000000
   Coding: 000000
   Coding: 000000
   Coding: A4FFFF
2 Faults Found:
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 22
                    Reset counter: 173
                    Mileage: 82957 km
                    Time Indication: 0
                    Date: 2018.02.27
                    Time: 11:43:37
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 17
                    Reset counter: 173
                    Mileage: 82957 km
                    Time Indication: 0
                    Date: 2018.02.27
                    Time: 11:42:42
   Coding: 10800A
   Coding: 7709010100
   Revision: B9080001
   Coding: 042307
1 Fault Found:
            000 - -
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 82957 km
                    Time Indication: 0
                    Date: 2018.02.27
                    Time: 11:39:57
   Serial number:
   Coding: 000000
1 Fault Found:
13705985 - Databus
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 5
                    Reset counter: 173
                    Mileage: 82957 km
                    Date: 2023.10.07
                    Time: 11:39:57
   Data carrier:
4 Faults Found:
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82957 km
                    Date: 2023.10.07
                    Time: 11:39:57
                    Voltage terminal 30: 11.9 V
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82957 km
                    Date: 2023.10.07
                    Time: 11:39:57
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82957 km
                    Date: 2023.10.07
                    Time: 11:39:57
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 172
                    Mileage: 82957 km
                    Date: 2023.10.07
                    Time: 11:39:57
   Coding: 030B1A73
End----------(Elapsed Time: 01:55, VBatt start/end: 13.0V/14.5V)-----------
  • adpmap-09-7E0-937-090_WV1ZZZ7HZGH044558-20231007-1149.CSV
The "60" is valid coding only on with EU6 engines with MFSW - defining which BCM pin is used for Cruise control by MFSW - thus fairly obvious (now) it throws BCM communication fault on EU5 engine.
Anyways, I'm fairly confident we are on right path - at least on the OEM path codingwise.
Not a factor on T6.
Thanks. Nothing obvious in there.
Just the channel 55 which allegedly should control lamp diagnostics but seemingly does not :unsure:
Ok mate. I’ll get a C revision HRCM in and code it in.
I must have missed this post from earlier!
Thats a strange set of error codes
The first few relate to coding/setup but normally when you see 'open or short to plus' it would imply a wiring fault
As i supplied the loom for this (even though i do make the odd mistake) then its unlikely that both inputs and both outputs are wired incorrectly ?!?!?
I would suspect the module is the issue, if it comes from the wrong vehicle then it will have the wrong dataset/parametrization data on it
I did take one from somebody that was having issues with a second hand one and there was very little we could do with it, i could find no parameter file for one online to flash into it and even ODIS refused to deal with it and after a few hours of messing around it was abandoned as unsalvageable, it may be quicker and easier to buy a new module ?
Thanks for your help so far @mmi, it’s much appreciated :thumbsup:
Reactions: mmi
Hi all, I need some assistance ... I am looking to buy headlights OEM LED to upgrade on my Multivan ... I found two of them (different sellers) with these catalogue numbers: 7E1941035A and 7E1941036 ... is there any difference except that one is made in 2016 and one in 2019?
If you’re asking if they are different variants due to one having a letter at the end, I can’t say for certain. But when I was looking it seemed to be that the lights with letters at the end of the part number were on LHD units. Which I presume is ideal for you?
too big a difference in the year of manufacture, can lead to a different shade of glow
There are several people that have/can do this for you
Volksfit @Eddcameron
@MAT@VWT5UPGRADES
Hazzydayz
SW Retrofit
Professional retrofits
Hello,
I've read the 57 pages of this thread ! And one conclusion : too much work for me to retrofit LED headlight by myself !
Appart this list, do you know other specialist to do the job ? As I'm living in Switzerland, if you know a garage based somewhere in Europe (France, Germany...)
Right now, i've fitted THQ H7 headlight, with regular H7 bulb. I'm thinking of moving to full OEM LED because H7 are not a big upgrade from H4
Thank you !
I've read the 57 pages of this thread and one conclusion: too much work for me to retrofit LED headlight by myself!
Apart this list, do you know other specialist to do the job? As I'm living in Switzerland, if you know a garage based somewhere in Europe (France, Germany...)
On the Kufatec website, they list recommend fitters for their LED upgrade kits -
Reactions: Jmi
No, not with VCDS.
VCP is the only tool capable of adjusting BCM parameters in such a convenient way.
Hi @Robert
Do you know if BCM25 coding with VCP require any login or security code?
Looking to fix the HBA issue, have purchased a cheap chinese VCP clone. I could connect to the different modules so it works, but BCM25 programming application is not able to read the values returning the message:
"Seed request rejected, rc :37 Required time didn't pass."
Any clue is welcome, thanks :D
Hi @Robert
as far as I know, the Chinese copy of VCP cannot read the BCM PQ25 eeprom
Aliexpress fooling me again
Thanks @F-roger for your answer
Will look for someone with -genuine- VCP or Odis+ near Barcelona, at least I know (thanks again to this community) the way to solve HBA problem after retrofitting the led headlamps.
