And that’s a wrap for the deadening!
B2B cable run from battery to behind drivers seat & the kiravans swivel is installed to boot.
Some great videos on YouTube - Lee from #CombeVallyCampers has helped so much indirectly
A few tips:
Deadening.
1) clean the area well.
2) heat dodo mat before application.
3) use nylon handles brush as a ‘dobber’ to work into corners if you don’t have hard roller.
Cable running.
4) 2x torque bolts removed above battery to gain access to cable routing.
5) ‘Punch’ bulkhead grommet else it will split if you knife it.
6) secure cable every 200mm approx to avoid movement (I used spare dodo)
Relocating connectors.
7) they easy fit under swivel - double sided down
8) You could disconnect plugs, but I just cut off the plastic holder I’d be binning anyhow.
Fitting swivel
9) wind the nuts on front 4x before cutting down.
10) don’t forget to cut the horizontal studs in the frame also!
