It’s been several weeks since my last confession - or rather forum update
but Xmas/work/travel & childcare has put a significant spanner in the works! Thankfully the festive slowdown has meant I could progress the “what to do next” tasks I also had pending.
So ‘
pop top’s’ - from Reimo to unnamed other brands, I’ve secured quotes from £2.5k & 1 day fitting to £8.7k & 7 days. For sure the most expensive one looks good (see image) & some nice features, but it’s all a bloody minefield IMHO. The differences just don’t justify the expensive as it’s mostly an ‘as supplied kit’ these days (Not like the 90’s T25 I did) & so I’ll be going to the middle ground with a local firm I expect.
Now ‘
beds’ are a similar story - again from Rock n roll to Rib, brand new to second hand. - I’ve looked at lots & noted costs from £0.7 to £3k - When you add upholstery (£500+) to the basic quotes & chassis plates (£150 plus fitting that are compulsory for the T6) it’s more like £1.6k to £3.4k. Given the seat will be used a lot, I’m going RIB 130 fitted as it’s not much saving to DIY when I add in the access hassle factory/cold.
Finally ‘
flooring’ - now this was a surprise as one firm will not touch my van unless a 1 piece 12mm floor is fitted by them at £700 with FOC contrax liner supplied by me! Another says that it needs a 1 piece 9mm from them is fine (£120 suppled or £250 fitted) & I can fit my own contrax liner - I also considered building my own 12mm x 1 piece with beach ply sheet (10’ x 5’) costing £170 collected + say 2 hrs to router it out…..or 9mm x 1 piece (£120 collected) as there seams to be no standard in this area
& the “crash test needs it” comment just doesn’t stack up (Long story - but I used to crash test cars for a living - if it needed this for the test pass it would be compulsory & clearly stated)
As such I now plan to fit my existing 3 piece x 9mm ply floor (biscuit jointed & glued) but then cross skin it with 2 piece x 3mm to ensure a good smooth base before the Altro contrax - I hope I’ve made a good decision - it might change still? Time to check out the forum!
