It’s a dry day hip hop hooray!
So on with the diesel heater install starting with the stand pipe fitment. I’ve run the van almost dry with 10miles left on the fuel gauge & likewise deliberately not topped up the add blue.
Up on ramps, plastic off & access to the tanks/pipes secured. Undo the fixings around the filler necks & removed the caps before prying the neck plastic off - refit the caps!
Remove the underbody plastics.
Disconnect the add blue supply pipes & if you can’t get the releases in, try my tie wrap trick!
You don’t have to but I choose to cut the fingers off a mechanic glove & tie warp in place to catch any excess (ditto for the fuel lines & electrical block connector) before pulling the entire add blue pipe assembly out.
Disconnect the central tank strap (13mm socket) & place the jack. Slacken off, then entirely remove the front & rear straps & lower the tank to the floor - without add blue pipes it’s a simple drop & nothing else is connected.
With tank on floor, pop up the red lock on electrical block from the fuel unit, pop off the fuel/return lines & you’ll be glad to have blocked on the other end of these pipes with glove fingers as this stops yet more diesel escaping.
Drive off the main retainer ring anti- clockwise with a wooden drift & lift the unit up. Rotate as you do to avoid damaging the float……and pour any excess diesel back in.
The big boss isn’t happy to loose the marigolds, but it does ensure nothing gets in to the tank when i’m doing the next steps.
