While I’m waiting for my VDCS device to finish the coding of my starter battery i'm going to attempt to put together a shopping list for my leisure batteries, DC/DC charger and associated cables, fuses etc. It’s probably more than obvious from the rest of this thread that I could probably do with all the help I can get.
The van is already converted (list of components at bottom) so it is only the supply and distribution of the power I’m dealing with here.
Attached is a basic sketch of my intended setup plus instructions for the CBE DS300 distribution board (already installed) and the Redarch BCDC1240D charger.
Shopping list:
Bosch LFD90 x 2
Redarc BCDC1240D B2B charger
Cables:
Twinflex: Starter battery to passenger seat 1600mm, Passenger to driver seat 900, Driver seat to dis board: 1000 = 3.5m (order 4m)
CBE DS300 back to starter battery (Single) 4 metres
Here are some things I could do with some help with:
1. Redarc recommend 60A fuse, I’m not inclined to go this high. What do others think?
2. Redarc's recommendation is 6 AWG up to 5 metre run and 4 AWG if unto 9 metres. Is 6 AWG (16mm2) enough or is there a benefit to going up to 4 AWG (25mm2)?
3. Is the earth best run all the way back to the battery Neg terminal as shown in my sketch?
4. Is there any benefit to an ignition feed? Or do I NEED this? Please see 2.3 on page 2 of the attached Redarc doc.
5. I have included a cable from terminal B2 of the distribution board which should apparently charge the starter battery when plugged into the EHU. Does anyone think this is worth it or having fitted the huge Bosch S5A13 will I be fine and never likely need a mains charge to the starter battery?
And:
1a. I will fuse between Redarc and starter?
2a. I will fuse between Redarc and leisure batteries?
3a. Should there be fuse between leisure batteries?
4a. Should there be fuses anywhere else?
5a. I would have liked the peace of mind of a safety power off switch but I have read somewhere that the join can cost you a drop of a whole volt! Is this correct and any other way of achieving what I want?
Obvious as it probably is, the red oblong is the starter battery and the blue ones the leisure batteries
Installed in the van (already done when I got it) is as follows:
CBE PC210 Controller
CBE CB516 Mains charger
CBE DS120-S Mains consumer unit
CBE DS300 Distribution board
Waeco CRX 50 Fridge (1.1 to 1.7 amps per hour)
Planar 2D diesel heater - using PU-27 Control panel (apparently 2.4 amps per hour, plus presumably start up amps!)
8 x LED ceiling lights (no idea of amps/watts used, presume negligible)
1 x 550mm LED strip light (no idea of amps/watts used, presume negligible)
Comet submersible pump for cold tap (10 – 24 watts)
Couple of USB charging points for iPad, iPhone and occasional laptop charging.
Shopping list:
Bosch LFD90 x 2
Cables:
And:
