But I am gonna check Your work / check the schematic diagrams..... but I think THIS tutorial.. is the easiest one... no need to spend anything, just time...
thanks
great job.
The voltage and temperature methods are no good for us as the channels are not on our gateway.![]()
. pretty awesome. As far as I know there is no way to do it via VCDS (actually there are 2 tuts.. one is changing some battery voltage value, second has got something to do with temperature...but not sure if that is the best way to do it..... unless the guy that posted that, knows that it does not have any side effects... I am not an vw software engineer jet
thanks
great job.
What amp have you got @Blitz ? I had this problem with a JL Audio, using DC offset to turn it on. I changed to signal sense and it’s perfect nowStop start cuts out my amp which is very annoying. I’m a button presser but would love a coding solution.
It can be turned off electronically using software called VCP thats how i have done mine, i know this is not really helpful to you here and know but i will take it to shows with me this year (bala/camperjam/busfest etc) so if anyone wants it doing at any of these shows just let me knowHello all, iv just got my T6 and the stop start is already driving me mad, has anybody found a fix to this ? or has anybody used one of the bits of electronics you can buy on ebay ? a hungarin one for £28 or a german one for £105 ?? the later looks a lot better but the instructions for the cheaper one are good. thanks for any help
Thank you svitky! I’m glad that someone appreciatets my efforts here. Let me know if you have any questions.![]()
thanks
great job.
Stop start will save the planet
Actually, a reduction in the human population would cure all the ills facing the planet, but nobody mentions thatStop start will save the planet
But then the alarm wouldn't set/work & you would have a permanent door open warning on the MFDAccording to the user manual, one of the conditions that prevents the start/stop operating, is the bonnet being open.
Would a simple solution be to simply intercept this circuit at the bonnet switch and either permanently make or break the circuit accordingly.
