Because it doesn't change..Why not just amend the long coding of the ecm and disable it lol nice and simple
address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7E0 907 534 HW: 7E0 937 090
Component: Batt.regelung H81 0744
Serial number: 0982 258161861
Coding: 530B1A73
Shop #: WSC 02739 790 00000
VCID: 68DA2C2A9B57AD0A7D-803D
Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K
Component: J367-BDMConti H03 1050
Serial number: 75410903001608200095
No fault code found.
Coding: 530B1A73
After:
Before:Code:address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb Part No SW: 7E0 907 534 HW: 7E0 937 090 Component: Batt.regelung H81 0744 Serial number: 0982 258161861 Coding: 530B1A73 Shop #: WSC 02739 790 00000 VCID: 68DA2C2A9B57AD0A7D-803D Subsystem 1 - Part No SW: 7E0 915 181 K HW: 7E0 915 181 K Component: J367-BDMConti H03 1050 Serial number: 75410903001608200095 No fault code found.
Okay different method, my start stop is disabled using the adaption I posted above on the battery regulator.Thats because your coding the wrong module mate! Coding on the engine control module not the battery regulator!
I tried the Engine control module 2 years ago when we first looked at this and it just threw up errors, but interested in the coding change you have used on the ecm..
Have a look through the search function. Absolutely loads of info on this subject as it's a desire for many.
Search Results for Query: Start stop | VW T6 Forum - The Dedicated VW Transporter T6 Forum
Any word on the coding?Ok as soon as i get a chance ill post my coding mate
can you have it on or off vis the switch now, or is it just off forever?Mine is coded out...
If your S/S isn’t kicking in, just be mindful of battery discharge in this cold weather.. might be worth checking with a meter / trickle charging overnight.Have t you got the button that you just press? Seems a lot of hassle reprogramming? Is their any benefit to this? Mine hasn't done stop start for ages with it being so cold. Not sure what everyone is going on about or have I missed something?
Yes, have the button, but its the times I forget to press it and it catch me out, so as I can program it fairly easily, I did.Have t you got the button that you just press? Seems a lot of hassle reprogramming? Is their any benefit to this? Mine hasn't done stop start for ages with it being so cold. Not sure what everyone is going on about or have I missed something?
Yes, but while the weather is bad i want to keep it dissabled.Have t you got the button that you just press? Seems a lot of hassle reprogramming? Is their any benefit to this? Mine hasn't done stop start for ages with it being so cold. Not sure what everyone is going on about or have I missed something?
