If I have captured this correctly there are two different ways to turn T6 engine supplementary engine heater to a remote controlled parking heater.
(A) - Reprogram the heater using tools+firmware provided by Webasto and use a remote control receiver + remote controller packaged by Webasto. The package+installation were described in thread
https://www.t6forum.com/threads/auxiliary-heat-upgrade.5029/ and also on pages 1-2 of this thread.
-------------------------- or --------------------------
(B) - Use VW OEM components and firmware to implement/add parking heater functionality on T6 (as from the factory on the vans in Nordic countries) as described on pages 4-5 of this thread --->
Webasto Auxiliary Heater - customizing .
For this functionality early T6s have remote control receiver 5Q0 963 513 A (with oval remote controller). From MY2017 onwards remote control receiver 3Q0 963 513 is used (square remote, as in the picture --> Webasto Auxiliary Heater - customizing )
The actual heater is identified on front door sticker with part# 5Q0.010.014.D (also the Nordic ones). However, when read (from controller 18) by diagnostic tool the identifier is HW: 7E0 963 273A or 7E0 963 272 A/B (Nordic ones).
It seems that
@wolny also has Climatronic A/C so based on the posts above the following steps are needed when using OEM components for a van equipped with Climatronic:
(3) Add a wire from remote control receiver (5Q0963513A or 3Q0963513) connector [A2_pin_2] to red connector [T17p_pin_1] (under left seat; there should be a green/white wire on Webasto side of the connector). Also wire permanent +12V, ground, aerial to remote control receiver. See details in the schematics --->
Webasto Auxiliary Heater - customizing and in the picture --->
Auxiliary heat upgrade
When remote is paired/communicating pressing OFF results a steady red light on the remote. On a non-paired remote pressing OFF flashes red.
I do hope recapped this correctly, any wrongs or hiccups, please correct!
