My fitting above the rad was also too looseThat’s odd as I got mine from Transporter HQ and it came with the fixings. Still it doesn’t fit as snug as I would like to and my OCD went through the roof trying to get it to fit perfectly. I even swapped out the fitting that fits above the rad as it’s just not good enough for me, way too loose.
I took the trim clip out and put a real plug and black screw in. Certainly doesn’t move at all now.My fitting above the rad was also too loose
I fitted a thicker trim clip instead of the one that was supplied and fits spot on now
@Marcovan8 Just as a matter of interest were you on Apple? (I am on Android)Hi got a link from ablemail and download app straight to my phone
Hi no on android Samsung@Marcovan8 Just as a matter of interest were you on Apple? (I am on Android)
Looks mint what is it?
EPIC!
Dont bolt it down to front scuttle, just use a plastic rivetOk so how these these fit, seems quite a poor fit
2 slots at the top that could conceivably just go around the 2 bolts that stick down but they don’t seem to attach anywhere?
1 bolt through the washer filler
1 bolt (probably need to add a rivnut? Into the front scuttle?
not easy to remove though if I need to check the oil !!!!
View attachment 103027View attachment 103028View attachment 103029
Good stuff is wet coat! Saves a lot of time, bathe+ is something id recommend too!Gyeon wet coat to see what it’s all about, having read some good reviews on here.
Ha ha ha! Turn off your wifiNothing today atm,
Still time yet though!!
If only I could...it would cause a revolution in this house and I would be overthrown within seconds....SWMBO's on her screen online shopping I suspect.....youngest doing an online lecture and eldest doing her latest Tok Tic!!....Happy days!!Ha ha ha! Turn off your wifi
