What Have You Bought Today?
Hi Jason do you have a link for the ablemail battery bluetooth monitor I got mine today but struggling to set up
Regards Mark
@Marcovan8 How far have you got with this? As I said to Jason you will need Ablemail to send you a link to download the APK to your computer. This is a personal time limited link so I am not sure if sharing the link would work.
*sigh* a battery charger as the van won't start. And also need it for my 350Z.
Yesterday was a rivet gun and rivets for a "plug and play" speaker upgrade :confused: rivet gun failed after first use and fifth use. Cheap Draper one, lesson learned
  • Sad
Hi thanks for the quick reply
Plugged the battman into my ams charger searched on Google apps but found nothing
Emailed Jonathan @ ablemail for a link but no reply as of yet
Thanks Mark
Buy cheap, buy twice?!! (A real bummer when it is a tool that only comes out once in a blue moon!)
Ok so how these these fit, seems quite a poor fit
2 slots at the top that could conceivably just go around the 2 bolts that stick down but they don’t seem to attach anywhere?
1 bolt through the washer filler
1 bolt (probably need to add a rivnut? Into the front scuttle?
not easy to remove though if I need to check the oil !!!!
9618AE82-E1B3-4127-BDAA-6A347243D5F5.jpeg1FBBD84D-967D-43A4-91C6-67A3997C0912.jpeg22F0AD6F-B7D0-40CF-BBF4-01228F7556DE.jpeg
Got my used drivers side H7 headlamp delivered......no bulbs and more importantly, no dust covers. I can reuse the large and medium ones from my H4's but it appears to need a funny shaped one too?
Just ordered a CPlay2air, no more iPhone cable connection :thumbsup:
  • Wow
Reactions: JOG
View attachment 103027View attachment 103028View attachment 103029
That video is easy to follow, only problem that you might have is that yours looks aftermarket rather than oem - but shouldn't make any difference
Also......did it come with the fitting kit??
Otherwise you'll have to buy it separately
Chinese diesel heater, for the garage.
Been considering heat options for a while, and will give me a chance to see if I want one in the van.
ah no it didnt come with a fitting kit that might be why dont suppose you know where to get one?>
its this part i need if anyone knows the part number or its name
/ Edit
In case it helps any one else from vdub transporters
  • 2x Genuine VW fixing mounts (part number: 7H5 103 943);
  • 1x plastic trim rivet (part number: N 911 585 01);
  • 1x black screw.
/ Edit
  • 1x black screw.
/ Edit
  • 1x black screw.
That’s odd as I got mine from Transporter HQ and it came with the fixings. Still it doesn’t fit as snug as I would like to and my OCD went through the roof trying to get it to fit perfectly. I even swapped out the fitting that fits above the rad as it’s just not good enough for me, way too loose.
Did you do the wireless charging mod?
Not yet, that’s next on the list once I get the airplay working, although thinking about it, it would make sense to order it to arrive with the airplay kit. Cheers @JOG for spending my money buddy ;)
I will order the parts and fit it then do some modifications I think, would like a snug fit and maybe a pop off panel so I can access the dip stick.
