Make sure you stick it on glass, they’re a pig to get off!A UK oval sticker !!
9 days til France !!
Too late ! Just above my T6 Forum sticker on the tailgateMake sure you stick it on glass, they’re a pig to get off!
I’ve bought a load of those ones you stick on the reg plate to avoid the horrible looking big ones
I also have one, it works a treatA little 800W oil filled radiator. Bought it in The Range for £20 yesterday - Go Outdoors have a Quest branded one with exactly the same spec for £45. We're off to North Devon (Mortehoe) tomorrow for the rest of the week and this will take the edge off if it gets a bit chillyView attachment 155125..
It took me pretty much all weekend to fit it all, and I'm not convinced I have it all set up properly yet, but so far I'm really impressed with it. The head unit it great and wireless Android Auto is brilliant. Sound wise it sounds much better than it did before, but i need to do some tweaking to get it sounding just right I think. Overall I'm really happy with it and with the service provided by Jason at Absolut5.Look forward to hearing how you get on and rate it. I've been eyeing up that upgrade!
Did you check to see if you needed the antenna adapter? I need it for mine.rcd330 From Travelinlite. excited to have Android Auto. Looked at aftermarket and it turned into a minefield of adapters and harnesses to get them working.
If they could just add DAB and another USB socket or card slot for audio input, I would happily pay double the current asking price.rcd330 From Travelinlite. excited to have Android Auto. Looked at aftermarket and it turned into a minefield of adapters and harnesses to get them working.
I didn't check. i just presumed it came with it? did you get yours from them?Did you check to see if you needed the antenna adapter? I need it for mine.
Volkswagen Radio Antenna Adapter Double Fakra 20cm RNS RCD 510 310 315 to RCD330 / RCD360
One Radio Antenna Adaptor Double Fakra Suit for VW, Skoda, Seat Upgrade from RCD210 RCD310 RCD510 RNS315 RNS 510 to RCD330 / RCD360 Easy to install, direct plug and play Please double check with your user manual before buying Description: FAKRA Connectors and Cable Assemblies support...travelinlite-transporters.co.uk
Trivial…!! That dial is the single worst part of any Vag car imo.Good for my needs.
Looks like a factory unit and doesn’t stand out within the dash.
Apple CarPlay for sat nav works well.
Audible (via CarPlay) works well for audio books.
I don’t listen to the radio too much but that’s seems to work well too. No static/signal issues either.
Steering controls all work.
My only issue is that there is a power logo on the volume dial. Changing the volume makes the logo wonky. Trivial I know.
Haha glad its not just me it bugs the hell out of me! I have to put it straight up and use the MFSW to adjust the volume!Trivial…!! That dial is the single worst part of any Vag car imo.
I always have it set at 12 O'clock and use the buttons on the steering wheel. Bugs me no end when a passenger adjusts the volume with the dial.Trivial…!! That dial is the single worst part of any Vag car imo.
I got one of the metallic ones only to find when I tried to put it on my Q5 tailgate it was made of plasticToo late ! Just above my T6 Forum sticker on the tailgate
Keep stereo knob at 12 o’clock and eject knob in passenger seat!I always have it set at 12 O'clock and use the buttons on the steering wheel. Bugs me no end when a passenger adjusts the volume with the dial.
On my old polo It came off when i was hoovering, just clips in so i might be tempted to take it out and spray it hahaI always have it set at 12 O'clock and use the buttons on the steering wheel. Bugs me no end when a passenger adjusts the volume with the dial.
