@Ukfozzybear do you any info on the kit you got for Xmas mate?I've been umming and arring over that kit. think i'll give it a go. Thank you
Is there a positive in there mate?Hmmm! Statement wheel. Statement flappy paddles. Statement leather trim. Now a carbon lookie-likey cover?
Three glaring ones....clue: starts with “statement”!Is there a positive in there mate?
How are the number plate lights different? I have the Travelin-Lite ones and one of mine is not working. When I fitted them to my barn doors I found they worked until I tightened the screws. I guess I need to loosen the screws a bit moreGot the blooming number plate lights working at last - what a stupid idea that barn door parts are different to the up and over door parts. Metal tape and sealant got the LED's working - hopefully no more blown bulbs.
Fitted one of 2 door card ambient lights - sure they will look more alive when dark.
Not really. Hence the reach out for thoughts.Are you sure?
Which one ?@Ukfozzybear do you any info on the kit you got for Xmas mate?
wasn't me that was @Daddio3750This bit:
“It was a Christmas pressie and came with everything, drill bit to the correct size, connectors, cable ties; everything. It was made up as a proper wrapped harness and was pretty good quality. Instructions were clear and easy to follow”
Cheers for the link ordered one @Ukfozzybearwasn't me that was @Daddio3750
what he was talking about is this....
I've just ordered one.
VW T6 Transporter Door Card LED Pocket Lights Interior Ambient Light Kit VW T6 Transporter Door Card LED Pocket Lights Interior Ambient Light Kit | eBay
The terminal ends are actually in a different style. One is longer and the other is shorter and fatter. I queried it with my supplier and they knew of the problem. It’s all about what ones the VW group fitted at the time. For example barn doors are the same as Skoda, Passat and golf, but up and over doors are the same as Jetta, phaeton and anorak. For example. Don’t know if those compatible groups are correctHow are the number plate lights different? I have the Travelin-Lite ones and one of mine is not working. When I fitted them to my barn doors I found they worked until I tightened the screws. I guess I need to loosen the screws a bit more
Was your solution to replace the lights or something else?The terminal ends are actually in a different style. One is longer and the other is shorter and fatter. I queried it with my supplier and they knew of the problem. It’s all about what ones the VW group fitted at the time. For example barn doors are the same as Skoda, Passat and golf, but up and over doors are the same as Jetta, phaeton and anorak. For example. Don’t know if those compatible groups are correct
That’s a lot of fiddly welding!Finished the welding of the seat base now to grind it back and smooth it off ready for paint
It’s called tenacity, something which I don’t have! Good luck @Niknak.That’s a lot of fiddly welding!
