Not sure I can be bothered now. Although now you say that I am going to have to do it.@Texxaco Are you not going to add the 30mm Sound Buffler foam on top? It makes a big difference.
Best to do it now otherwise it’s another cleaning sessionNot sure I can be bothered now. Although now you say that I am going to have to do it.![]()
After swearing at the rivet gun which made the job difficult, I mounted the Eton speaker in the driver's door and closed the door card one final time. I don't have anything on the job list that requires the door card off ever again!
Well, that depends.....though I don’t know how easy @Andysmee’s arse is! Just saying, not asking!!!Plug and play. That statement annoys the bejesus out of me. It’s never that easy. Ever!
I reckon you gotta do it now! @DXX has given me a load of advice on how to go about this job and posted on here about itNot sure I can be bothered now. Although now you say that I am going to have to do it.![]()
And lots of Savalon on your hands after, Edward Sissorshands!So that’s another winters evening sorted out![]()
Yeah something like that.And lots of Savalon on your hands after, Edward Sissorshands!
Where did you get the 30mm buffer @DXX ?@Texxaco Are you not going to add the 30mm Sound Buffler foam on top? It makes a big difference.
@Texxaco One sheet is plenty, it’s good stuff but currently out of stock.
This stuff is like rocking horse poo @DXX .@Texxaco One sheet is plenty, it’s good stuff but currently out of stock.
I wouldn’t use the 10mm stuff you listed, I have used it elsewhere and linked it on this forum way back.
Silent Coat Noise Buffler 30mm Bonnet Liner
The Silent Coat Noise Buffler 30 is a sound absorption blanket made with a special formulation acoustic material, 30mm thick, with an aluminium foil face and a self adhesive backing. This product is specifically designed as a noise absorbing liner to sound proof a car bonnet, engine bay or...www.deadening.co.uk
Does it soak up water @DXX?Best to do it now otherwise it’s another cleaning session
For anyone that would like to know what puller I used to get the wipers off. Image below sourced from Amazon.Covered the scuttle in Dynamat Extreme over the past two evenings in the Arctic weather we are having. Had to use my heat gun to warm my fingers at one point. The things we do for our vans!
Anyway it’s all done now.
Considered the scuttle but down the list as aim is to get the van on the road again.For anyone that would like to know what puller I used to get the wipers off. Image below sourced from Amazon.
Do make sure that you leave the wiper nuts on when using the puller as the puller bolt is hollow.
Here you go @Graeme_BConsidered the scuttle but down the list as aim is to get the van on the road again.
Hadn't really looked into what was required. Can you share the link as will prob do this at some stage.
