Definitely easy to fit but hindsight I’d of powder coated the brackets BlackNice trapezoid bars those. Definitely gone on the list! Saw another review about the build quality of those and the ease of fitting. Would you agree?
At Lookers, Stockton ?Just dropped it off for 1st MOT, oil change and "Alĺ in One" check.
Hi and well done But did you not look at Combe Valley campers Video on U tube before starting your Cable run it's always worth having a swat up before starting projects... they give plenty of tips and short cuts might save you some time searching the route.I threaded a mains cable into my cabin from the engine bay this afternoon. I found that the metal panel behind the battery is secured with two torq bolts, one under the plastic trim under the windscreen and the other on the right by the bonnet hinge. It then comes away and revels a void with a round 50p sized rubber grommet. I found that sitting in the passenger footwell, I could thread my right hand under the dashboard, after pulling the cover under the dash off. I located the rubber grommet in the fire wall and pushed it out.
In the metal panel behind the battery, I made a 20mm hole for a plastic cable gland to protect the cable from sharp edges.
After threading the cable through, I wired in an inline RCB and an ABB make connector, which now sits infront of the battery.
I have left the cable stowed under the driver's seat for now but plan to route it under the cabin carpet to the driver's seat and wire up a single socket to allow me to plug in a multiple extension cable when static. I can also plug in the leisure battery charger when at home.
Apologies for no images.
@Sackmycook - No, they have moved now to Lookers, Cannon Park, Boro.At Lookers, Stockton ?
Mines due there in a few weeks so be interested to see how they do
I'll wait for them to let me know then.@Sackmycook- They have only recently moved to the address in my previous message. They only called me yesterday to inform me they have moved
Did they give a price? Mine needs doing by end of monthBooked in for an MOT, Cambelt and Water Pump change at Midland VW (Cannock). Seen lots of positive comments about them, and they are not very far![]()
