Nice!Fitted a 1000w flush mounted induction hob powered by my Ecoflow Delta Mini. Takes 2 minutes to boil water for a cup of tea
@ChrisWatson No worries, what material are you going for?
The Audi liner also - just moved over to van ownership after an 8V Audi S3 and there’s a few creature comforts that I’ve been missing so gradually getting them sorted. Considering doing the door card panels too but I’ve seen some moody jobs done so my guess is it’s quite challenging.
My Lazers don't have these, but reading through a generic wiring instructions, the ones that come with the position lights have an additional wire in the loom that connects to the side light circuit.Appreciate what you’re saying about the full beam… totally understand that bit…. I’m more interested in the DRL part?
I don’t really know what a position light is?Oh right..it's more of a position light than a drl if that helps?
The position light part of these is I think a different set of LEDs in the unit. I wired mine to come on with dipped headlights but you could use the DRL feed I suppose. The problem I had was I didn't like the look of them. The colour temp is warmer than the OEM led headlights and just looks odd to me. I've disconnected the position light wire now so they just come on full beans on high beam. They are mind blowingly bright , quite literally turn night to day. Had mine 2 years ish now and wouldn't be without them . Worth the money , quality is excellent.I don’t really know what a position light is?
The questions that I would like to ask you if you don’t mind (and this is where I said it would be interesting to see a run through of your light sequence)….
When you turn on your van and it’s running, are the Lazer Lamps on as a DRL?
When you then switch on your sidelights, then headlights, do the Lazer Lamps stay on as a DRL but dim down?
Obviously on ‘full beam’ it’ll be all guns blazing!![]()
Same here, Thames water ended it tooCleaned it as Yorkshire Water have ended the hosepipe ban !
Thanks for that mate…. interesting!?The position light part of these is I think a different set of LEDs in the unit. I wired mine to come on with dipped headlights but you could use the DRL feed I suppose. The problem I had was I didn't like the look of them. The colour temp is warmer than the OEM led headlights and just looks odd to me. I've disconnected the position light wire now so they just come on full beans on high beam. They are mind blowingly bright , quite literally turn night to day. Had mine 2 years ish now and wouldn't be without them . Worth the money , quality is excellent.
would be good to know what you think of it when your done pleaseStarted fitting my ovano table, the leg and support are fitted, just got to figure where to mount the table base onto the table![]()
Will do , hopefully all done tonight, I'll let you know but first impressions are very goodwould be good to know what you think of it when your done please. I've been eyeing it up just not pulled the trigger yet
How are you finding this unit? Does it have access to the storage from the top?Started wrapping the Van Furniture Kombi Pod in Balckwood Wrap.
