Looks like a good shout that!Just found this deal, seems too good to be true but looks legit. Dodo Juice Blue Velvet Pro Panel Pot
How do these come off as I have a few on my shuttle do these just prise off? ThanksChrome is now gone, super easy job but mate a nice subtle difference.
View attachment 189058View attachment 189059
Yeah absolutely, that’s one job I am holding off on till last but I do intend to do them before BWT show in July.Ok sounds good, I might give it a go.
Would you say it’s strong enough for door cards?
Yeah I popped the top of the grill loose so I could I clip from the back then a trim tool to pull off….all done in 20 minsHow do these come off as I have a few on my shuttle do these just prise off? Thanks
Did you replace the part behind the main Vw badge does this need to be swoopedChrome is now gone, super easy job but mate a nice subtle difference.
@Albel no you can re-use the backing it’s not part of the badge, easy to remove with a trim tool no need to remove the grill just get the tool behind the badge in the outer edge and work your way around.Did you replace the part behind the main Vw badge does this need to be swooped
I am after a Matt black look is yours gloss ?
Lastly did you do all that without taking the grill off cheers
Cheers makes sense are your grill trims gloss as well or matt ?@Albel no you can re-use the backing it’s not part of the badge, easy to remove with a trim tool no need to remove the grill just get the tool behind the badge in the outer edge and work your way around.
Yes mine is gloss
If your asking about grill for the inserts I remove the trim clips from the top of the grill to get ny hand behind and pop the clips off whilst using a trim tool on the front to lever them off….
Gloss alsoCheers makes sense are your grill trims gloss as well or matt ?
Here ya go.Are they quick release couplings on the hoses? If yes, would you have a link?
Thank you and once trims off should be no mark on grillYeah I popped the top of the grill loose so I could I clip from the back then a trim tool to pull off….all done in 20 mins
No marks no, just the slots where the trims clip inThank you and once trims off should be no mark on grill
AceOne piece, rebated 18mm birch ply floor
Just picked up the freshly MOT'd camper - no advisories.Took the 4 year old Bus in for a service, MOT, cambelt & water pump at the local van centre.
Wish me luck...
Thanks for all the likes - gives me a bit of confidence that the change was the right one
