Looking around at the moment, forty winks have some but £10 each plus postage![]()
Ouch - I guess they want you to buy their system!
Cut and bonded our barn door windows. Starting to feel like an actual conversion now!
Nice @Steve Davies is that a LWB, or a very short bed?Following on from my self-build bed, done over three years ago now, I've built a storage unit/work top that locks to the bed frame. Everything is still removeable for when I need to use the van as a van or people carrier.
LWB. Bed is 1.9m long.Nice @Steve Davies is that a LWB, or a very short bed?
Lifted the driver’s seat to replace the LB. Don’t know what these wires are and where they should be mounted. Any ideas would be greatly appreciated
Sorry I'm afraid thats where my electrical knowledge finishes@Peatey , you’re a top man. And where does that little black clip go?
No problem. Your knowledge is superior to my ignorance on these matters! Thanks againSorry I'm afraid thats where my electrical knowledge finishes
I don't have a black clip but the other clip is fixed to the underneath of my seat
Roof rails hide aRemoved Kombi ceiling panels in preparation for drilling 5 holes in the roof - 4x for the solar panel fixing bolts and 1x for the cable.
I also assembled the Aero mounting brackets onto the panel and discovered the ridges in the roof of the transporter mess with them.
So I had to ‘mill’ (with my circular saw) some indents to match the profile of the roof ridges
And then I offered up the panel on the roof - it sits much better across the ridges now but I’m undecided whether I like the looks of the panel on the roof from side view and from the front - even taking into account the black panel, black aero mounts and black van.
But I’ve bought it now and mullered the aero brackets so can’t return it
I hate doing anything other than sitting in the chair these days as nothing ever goes right.
Now looking at roof bars to sit either side and hide/take your eye off the panel.
Apart from £350 up my shirt I’m not committed yet as haven’t drilled any holes in the roof.
In other news I was charging the EcoFlow with the panel stood up against the garage door at 85w in the partly cloudy sky - so this will easily keep it topped up as I have approx 3w continuous drain from cctv camera and mobile broadband
It’s intended to keep the wire in such way that it will not grab or snap when you move the seat back & forth and swivel. Just move seat carefully while watching the wire and find a place to snap it to based on that. It’s just a fancy cable tie.And where does that little black clip go?
Thanks @Bri1701. You’re right, they are swivel seats, so I’ll leave it loose. CheersIIRC when I looked at mine a while back the clip thing is attached to the seat base metalwork somewhere in the middle, but looks like you have factory swivels? So maybe it needs to be loose.
Silly question - what does it look like under your passenger seat?
Thanks for the pic and info - yes, that’s certainly a good way of mounting it.Roof rails hide a
Multitude of ugliness and a few L brackets and rivnuts simplify the assembly with no holes in the roof… other tha the cable glands which are easily hidden under the panels. Although, clearly, mine are not!
Also my Skyline roof is a bit flatter than yours so you just have to be careful about the height of your mountings. I did have mine on before the pop top too!
Does this make any difference to driveability?? ( not a mechanic)Changed the rubber bushes in the front suspension arms to poly bushes.
