What head unit have i got? Reverse Cam? Sat Nat? PDC?
Pauly........how much just to do the front sensors and what would I need? Not bothered about a reversing camera.......just the front sensors.
Cheers mate.
All prices inc vat invoice & delivery and all parts require coding to enable
Tailgate camera kit £28o
Barndoor camera kit £340 (includes replacement trim above number plate with numberplate lights in)
PDC F & R kit £580 (includes upgraded 8K control module, x8 sensors, x2 beeper, wiring, dash 'P' button, x4 front grille panels with modules pre fitted)
PDC Front kit £480 (includes upgraded 8K control module, x4 sensors, x1 beeper, wiring, dash 'P' button, x4 front grille panels with modules pre fitted)
PDC Rear kit £380 (includes standard 4K control module, x4 sensors, x1 beeper, wiring)
Rear sensors can be colour coded for around £30 but adds 1-2 days to the order but only necessary when adding rears to a trendline
I used to laugh at the thought of needing front parking sensors and rear cameras but have to eat my words they are really useful.
Had to reverse into a tight space last weekend and the rear camera with the guide lines made it easy, just as well as my brother in law and his T4 crew were waiting to take the piss out of me if I cocked it up!
Hi
Just came across your posts. Sounds like just what I need. I have a 16 plate t6 high line that has rear sensors. I would like to fit front ones. Pally am I right in thinking that it would cost me £480 if I ordered it from you? What about upgrading to a camera at the back and front sensors?
Hi, I am fitting a reversing (OEM) camera, and I am told to plug one cable into number 6 and the other into 12, but which ones are they on the blocks?
Does anybody have a map or diagram of the block and what res where please?
Hi, not sure of the model name, its standard on the highland kombi with apple play, full sat nav etc, is that enough?
Thank you i will, really appreciated.
One question regarding the VIP,
  • Access to precompiled speed camera database for Discover Media headunits
How does this work, do i load onto SD card, and is it for just UK or Europe?
So the wires will go in the grey plug?
Hi, I have only done the UK ones so far but they are due an update so will add the euro ones as soon as I have chance
Thanks, how do i download them please, then i suppose i copy to the SD card, and add the POI to appear on the naV? Europe would be good for me as I spend most of my time there.
That looks like a compatible headunit H is ok it's the b/d/e/l models that aren't AFAIK
