Maybe it isn’t. I’m not sure but I do like the feeling of coasting yet knowing the car will engage gears again as soon as any input is made.I’m not so sure the coasting function is fuel efficient. It basically puts the car into neutral every time you lift off the accelerator, so the engine will use fuel, otherwise it will stall. Without the coasting function when you lift off then no fuel is being used.
There may be occasions when coasting has an advantage, but over all driving it uses more fuel.
I believe this is the main reason VW stopped putting it on the T6.1.
Thanks for the explanation. My GLC has a similar feature.In the golf there is a drive mode select button by the gearstick or I can select modes using the sat nav/radio screen (mmi?)
It has sport, normal, comfort, eco or individual where you set the various things (engine, ac, shocks etc) the way you want. The coasting function only happens in the full eco mode. Setting the engine to eco in ‘individual’ mode doesn’t activate it.
I’m not sure if coasting is only available on vehicles with the dynamic chassis control and dsg together? Have a vague recollection of discussions on the in the golf forum.
Indeed no fast car required to do 70 but easy cruise at 65 with family and no rush. Don't stress though I don't sit in the middle or outside lanes unless passingThat’s impressive and highly Boring but this days seems the norm. However to drive 70mph on the motorway you don’t need a fast car
How many miles do you get out of a tank?South Northumberland to The Wave Bristol and back............cruise on at 65mph, some traffic but nothing major aside from static on A19 for a hour for a crash but that was engine off. Average speed came back as 47mph.
102bhp 5 speed on standard 16 inch wheels and tyres 56psi front 50psi rear. Stock van sound dead, insulated and carpet lined, 3 people and surfboards.
Tend to see around 44-46mpg normal daily use but I drive with a very light right foot and love an eco challenge! if I want to go fast I drive a fast car![]()
What RPM is a 5 speed doing at 65mph? My 150 DSG was doing 1800rpm with the cruise set at 66mph all the way down France and did and worked out with maths 36mpg.South Northumberland to The Wave Bristol and back............cruise on at 65mph, some traffic but nothing major aside from static on A19 for a hour for a crash but that was engine off. Average speed came back as 47mph.
I’d have to check…. I can’t remember!What RPM is a 5 speed doing at 65mph? My 150 DSG was doing 1800rpm with the cruise set at 66mph all the way down France and did and worked out with maths 36mpg.
Have you checked your tyre pressures? 36mpg at a steady cruise seems low, even for a van.What RPM is a 5 speed doing at 65mph? My 150 DSG was doing 1800rpm with the cruise set at 66mph all the way down France and did and worked out with maths 36mpg.
120 mphI’d say 36mpg it’s great. Never seen that much on a long run
Managed from glasgow down to Folkestone 38/40mpg( probably more can’t remember) but going slow at 60/65 mph. Once in France got carried away exceeding the speed limit just a bit not to lose my driving licence…140/150kmh. Then Germany lost my mind. Couldn’t Push it over 120mph. Is there a speed limiter?
Tank didn’t last long but still return 25mpg, most of the time driving aroung 150-160kmh.
Average from beginning of ownership 30-31mpg, 1 mpg better than my previous 2008 2.5 tdi 130hp.
Driving by myself with 5 seater configuration, roughly 50/60kg in the boot. Tyre pressure 3.3Bar (47psi) on 18” 255/45/18 Michelin Crossclimate. 150 Dsg (remapped).
I just can’t imagine the noise but then my van is 102hp and five speed so it’d be revving it’s nuts off if it could even reach 120mph.That was an attempt to check the max speed of the Brick. once reached 120mph on the clock, and it doesn’t take too long to reach it, even down hill doesn’t speed over 120. Didn’t check gps but real max speed probably 110 .
It feels well planted at that speed on long straight German motorway. However I find the sweet spot being aroung 90/95 mph. I have drove all Germany down to Austria at that speed without being tired after nor stressed. And it saved me a couple of hours compared to drive at 70mph.
I used to do the same journey with more powerful cars at speed over 140mph but I wouldn’t drive anything else other than my T6 now. Maybe it’s age related…
The size, view out the windscreen, the driving position and the space for rest stops is awesome in the vans. I do really love that aspect like you do.I see your point but to me when I arrive somewhere I get bored. I use
The van now like I used my cars. I love it because of its driving position, size of it to protect in case of an accident and presence on the road. Being a Caravelle insulation is very good and there is no much difference driving 70 or 90mph. Bit noisier over that speed but still decent.
Lived near Frankfurt for a few months driving a Merc w126 560 SEL with 20” alloy and Bilstein coilovers. What a Motorway tank.
I had a manual (6 speed) golf mk6 estate previously and now have a mk7 estate with the 6 speed dsg. Both 2.0 Tdi 150 engines although the mk6 was the blue motion car with eco tyres and aero grille/mirrors.I'm certain the DSG kills my mpg, I'm averaging 35.6 overall, worked out properly. I think I'd go with a 6 speed if I replaced it as I'm sure I could drive it more economically than the DSG allows.
