There’s some listed in the For Sale sub-forum.hi
can anyone point me in the direction of where i can source original wheel bolts? or a set of locking nuts that would fit original 16" steels
thanks
thanks
I believe someone did this by putting a bit of plastic pipe inside the centre caps to reduce the diameter. Its on this forum somewhere but I cant find it at the moment.Anyone knows if VW oe steel wheel centre caps will fit to 17mm head wheel bolts? I believe that oem bolts have 19mm heads and I need to use 20mm spacers but longer bolts are only avaible in 17mm heads. A lot of options for bolts in UK but almost nothing different is available in Estonia. Would be happy to order them from UK but from this year they changed tax system so I have a lot of problems these days to modify my van.
Hi Oli,As above. Your standard bolts will work perfectly.
Depends on what bolts you have presently. Can you take one out and take a picture of it from the side.
We have plenty of bolts in stock, but silver. Just use black caps.
Can I call the office Monday and order? Cheers.Ok. So you need a full set to replace your alloy ones.
I would take a puncture repair kit. puncture repair kitI removed the 16inch steels and fitted alloys with new bolts a few years ago (van is a 2016 140bhp van if it makes a difference). I’ve only just realised the bolts on the alloys won’t fit the original spare wheel (haven’t tried it but from reading on here). I’m going on a week long trip next week and my original bolts are in storage as I’m in between houses.
Can someone clarify the part number for the bolts I need for the spare please? The doc Loz posted says the part number is -WHT 001 964 A- but when I search that online it says not suitable for my van.
Any help appreciated. Will be Sod’s law I get a puncture next week now that I know this
I’m using the factory wheel bolts and lockers on my Supermetal Tridents. HTHQuestion please...
Can anyone tell me if SuperMetal Cells use standard T6 wheel bolts or do i need to order specific ones?
thanks
Thats because VW sell the Tridents. I dont think you can count on the cells being the same.I’m using the factory wheel bolts and lockers on my Supermetal Tridents. HTH
If you have no luck you could ask here, ask one of the forum traders who sell them or ask on one of these tagged threadsQuestion please...
thanks
Found the answer on the thread you suggested. They take OEM wheel bolts and lockers if anyone wanted to know.If you have no luck you could ask here, ask one of the forum traders who sell them or ask on one of these tagged threads
supermetal cell wheels
www.t6forum.com
