No problems
As long as all
4
Tees are the same
Size you will not have any issues
As long as all
4
Tees are the same
No problems
As long as all
4
Tees are the same
Yes mate, I love the steelies for swamper look. Would have gone with wheller 17's if funds would have allowed, but the camper conversion comes first for now.I'm heading the same way @tifflepops ... Nice look. Don't those steelies look great powder coated.
This is a big tyre 25mm all round increase in size; 7.5% increase in gearing.Hi all, will I need spacers if I fit grabber at3 235/65 r17 on Davenport's, standard ride height? Thanks ( sick of the lack of grip on conti vans)
Evening Bud,Hi all, will I need spacers if I fit grabber at3 235/65 r17 on Davenport's, standard ride height? Thanks ( sick of the lack of grip on conti vans)
Try this website very useful...Evening Bud,
Im not 100% sure if anyone has a mathematical formula that would work your question out but i have run both 235/55/18 and 235/60/18 AT3's. All standard ride height and all turned and compressed with no scrubbing at all.
Sorry i cant answer the question fully.
Hi Chris. I have read the whole thread. Earlier in it you recommend 225/65 r17 but here say that 235/65 r17 are pushing it. Surely they both have the same rolling radius, with the 235 just being wider. The gearing ratio would be the same wouldn't it?This is a big tyre 25mm all round increase in size; 7.5% increase in gearing.
You may just about get away with it, if you travel lightly loaded, and the terrain you travel is not too undulating; and you don't drive too fast.
The worst case is on full lock; or heavy compression you start to rub the plastic liners. You may just rub on the inner metal on full lock, but you can always "unlock" the wheel slightly to stop this.
To minimise the likelihood of never catching the plastic liners/ inner metal, fit 25mm spacers all round.
The 65 is the aspect ratio of the tyre expressed as a %. So to work out the amount of side wall rubber you have you do this:Hi Chris. I have read the whole thread. Earlier in it you recommend 225/65 r17 but here say that 235/65 r17 are pushing it. Surely they both have the same rolling radius, with the 235 just being wider. The gearing ratio would be the same wouldn't it?
Thanks, now it makes sense.The 65 is the aspect ratio of the tyre expressed as a %. So to work out the amount of side wall rubber you have you do this:
65/100 * 235= 152mm of side wall rubber;
65/100 * 225= 146.25mm of side wall rubber.
only 6mm difference but that is a significant difference to gearing, and the likelihood of the tyre catching, particularly if you are lowered or carry heavy loads.
I have run tyres the same size (rolling radius) as 235/65/17 (255/55/18's), and it was just a tad too much imo. But they looked brilliant, just my opinion, and I'm sure there are people on here happy with this large size; particularly people with a suspension lift or Air.
Next and final question.
Yoko geolander ATS Vs ko2 in size 225/65 r17
Yoko are speed and weight rated, have used them before on my last van, an lt35 158. They did 25,000 miles without any noticeable wear and also let me.drive through an ice storm.
Have not used the bfg ko2 tyre before, and it does work out as £200more fitted.
Yesoggi sono triste .... la polizia mi ha fermato e ha controllato l'indice di carico e velocità dei miei amati BF .... ovviamente il 103S non è buono per il mio T32 (sui documenti è almeno 106T ..). .. per fortuna non hanno confiscato il mio documento di registrazione e non mi hanno dato multe ... ma ho dovuto rimuovere i BF dai cerchioni .... peccato, a parte il rumore, stavo molto bene ... montero loro sulla jeep, ma la mia California è scarsa ...
whoop whoop - è il suono della polizia.oggi sono triste .... la polizia mi ha fermato e ha controllato l'indice di carico e velocità dei miei amati BF .... ovviamente il 103S non è buono per il mio T32 (sui documenti è almeno 106T ..). .. per fortuna non hanno confiscato il mio documento di registrazione e non mi hanno dato multe ... ma ho dovuto rimuovere i BF dai cerchioni .... peccato, a parte il rumore, stavo molto bene ... montero loro sulla jeep, ma la mia California è scarsa ...
