Hi. For the year I’ve had this T6, there have always been two two faults codes from Carista:
05273
05459
The van runs and starts like a dream. @mmi rightly suggested this:
I had the battery tested and it’s tip-top. I’m aware that these might be ghost codes from Carista, but don’t have VCDS.
The codes have been nagging me though.
Then I noticed that @mmi and @Loz had diagnosed a similar fault code as being an immobiliser:
05273
05459
Carista might have padded the fault codes by leading zeros thus turning the actual codes to something different. I would verify the codes with a proper tool.
Meanwhile, I would guess the codes actually are:
5273 - Output for Starter Relay - P0616 00 [032] - Short to Ground5459 - Control Circuit for Starter Relay 2 - P3048 00 [032] - Short to GroundSo simply intermittent low voltage (which looks like a short to ground) during cranking (poor battery perhaps)For Transporter e.g. here:Transporter t6 bcm problem
hi lads/ladys , l have a customer with a t6 VOLKSWAGEN TRANSPORTER T28 TDI P/V TRENDLINE BMT VIN: WV1ZZZ7HZGH129480 Bhp: 101 Reg Date: 28/06/2016 Engine Code: CAAB he bought van with with faulty bcm he thought and ask me to program in new one . he has bought one with all the same numbers, l...forums.ross-tech.com
25665 - Output for Starter Relay - P0615 00 [032] - Open Circuit
25670 - Control Circuit for Starter Relay 2 -- P3049 00 [032] - Open Circuit
So I wonder - since it’s ex-fleet, if there might be some relic of a second immobiliser. I’m going to have a look under the battery tomorrow to see what I can find. Does anyone know what I should keep an eye open for? I was thinking a relay that isn’t part of the OEM relay suite, extra cables.That’ll be the immobiliser, they have tapped into the bcu feed that goes through the 5a fuse that supplies the 2 starter relays.
