The interior . . . .
well after flip flopping and u turning way to many times.
i think we have a made a decision.
the 120 bed seems to have been phased out.
we made up our bed with storage boxes to simulate the standard 2/4 112 bed width, and well have to make do.
there will always be the rull width bed in the roof anyway if things get too tight.
weve decided to downgrade from the rails system, and upgrade the bed from the RNR to the RIB.
there are many reasons for all the above. but the long and short is the rail system is way more expensive and needs a pro fitter to be done properly.
where as the other options, i can do myself - with some help.
ie
remove kombi 1+1+1 system, seats, brackets, seatbelts, floor etc.- offer for sale on T6F
remove the OVANO - offer for sale on T6F
install one piece floor,
install flatpack kitchen cabinetry,
install fixed RIB bed.
well get prices for fitting as well. - but the first place we spoke to wanted £500 just to remove the kombi stuff!!
so what we looking at?
this slate grey / dark grey panels with Oak worktop and splash back.
soft close, pop out buttons,
high level lockers
and the Boss wants the pull-out draws under the bed.
as we both decided we didnt want to do cooking inside,
but water and sink WAS required,
a lot of these builds come with the Dometic 9222 or whatever it its call, so we thinking about getting that fitted, and either not using the gas hob,
or maybe just hooking up a C500 can as at temp?
we are also very interested in the Microwave thing, as well as out small kettle and CTIZ coffee machine.
i think well just have to get it fitted. . . then just find out where to put stuff.
theese guys also off the floor as well, 9mm or 12mm etc.
as for the bed. . .
it seems that the RIB Altair 112 is best suited for us.
so we might be able to get the floor, bed, and kitchen for 4-6K.
now we need to get some prices together,
and one place is in Thetford, only 2hrs away from us. for an eyeball.
the other big deal is . . . poptop or interior first?
we know we would like the VANMAX poptop.
so was planning on getting that fitted first, and having the interior done next?
thoughts?
EDIT:
Van Furniture are a unique camper van furniture manufacturer producing side kitchens, worktops, wardrobes, ply kits, roof linings and unique storage solutions.
www.vanfurniture.co.uk
we looking at this one. . .
K2 Trim Edge Kitchen & Altair Rib 112 Rock N' Roll Bed Bundle (Fixed)
from £3,200.00
After a long time coming we are now happy to be able to offer our Kitchen and Rib 112 Bed in a discounted Bundle package. The Rib Bed is a M1 crash tested double seat that upon pulling out makes up a full bed.
Upholstery varies from the Simora and Brick style.
Our Kitchens are pre scribed to the T5/T6.
K1 Is our original Live Ply Exposed edged kitchen , The K2 is a lightweight Ply with knock on trim .
This can be collected from our workshop for no additional cost or we can send out Kitchen and Rib bed out on two pallets for £150.
Optional Extras:
Front & Back Bed Board +£200
Oak Folding Table & Leg kit +£150
Oak Veneered Window panel +£130
Both SWB & LWB Kitchens come with Top Cabinets.
Standard Bed Boards are showcased below in the final set of pictures, we have between this and the the sliding drawer units (Featured in main renders)
Drawer Bed Board units do not have a back panel , please message for more details.
Self Build & Pre Assembly options
Our Self-Build kits come with full instructions and all relevant fixings provided. Timing for assembly is highly subjective depending on your skill level but on average for a fully built kit that is sanded, finished and installed we would recommend a days allocated timing. We would say this requires a good grasp of DIY ability but we are always there to help if you run in any trouble, with us having fully assembled kits in house we can use for reference and send pictures of.
You can add pre assembly to this
here.
For a guaranteed hassle-free experience all of our kits are available for pre assembly and can be collected directly from our workshop. We often have many kits built up in our showroom which you can find
here .
Pre Assembled Pallet Delivery for Mainland UK is £150. Please contact us for Channel Islands and Scottish Highlands as charges for these will be more.
Please note Satin Black colour option is currently a 6-8 week lead time.
with the extras. . .
they also do a 9mm OAK floor to match - which we like.
9mm Oak Floor - SWB T5 T6
£195.00
** Please note our roofs & floor kits are strictly collection only **
If Collecting from seaside campers there will be a 1-3 week turnaround for LWB.
Render images showcase the design perfectly, some of pictures showcase overhang on sliding door step, this is no longer the case.
We cannot pack these for your own courier collection, collection in person from our workshop only.
A unique new oak flooring for VW Transporter T5 & T6 in SWB & only available at Van Furniture
Real oak veneered 9mm floor, supplied in 2 large pieces, CNC cut to size for the perfect fit, this is not a cheap plastic veneer.
Our Van Furniture Oak Floor is CNC machined with V Cut lines to give a real wood slat effect but is supplied in sheet form ready to install and cut to size. Floor is supplied in 2 pieces for easy fitting, the joins are hidden in the V grooved lines. Install time of a solid wood floor could take several hours, this T5 T6 oak flooring kit in a solid sheet will take 10 minutes.
Finishing: Our oak floors are supplied sanded in its natural form, these floors work great and look fantastic with a floor oil, this gives the flooring protection and shows off the natural warm biscuit oak colour. Our floors can be stained or painted and colour, this is not a cheap plastic laminate.
Note: this is a real oak veneer so is a natural oak wood grain, each piece is different and unique, each piece and each side is different to the next.
Weight: 17 kilos.
Step: We machine a standard full step, Kombi steps fit best over any ply floor.
Our Floors are made from 9mm Oak Veneered MDF.
other options are the fridge and sink kit. . .
Bundle Deal - Dometic 9722 Hob Sink , Tap ,Water Pump Kit & Fridge
Sale Price:£750.00 Original Price:£796.50
This is available for free delivery alongside any U-Shape bed or full Kitchen Pallet delivery. On its own is a collection item only.
Dometic 97222 R/H Sink and Two Burner Gas Hob – Campervan Two Burner Gas Hob Combination Unit with Water pump kit & Alpicool Fridge all at a Bundle discount!
Can be used with our Van Furniture SWB U-Shape, One stop shop for all your camper kitchen needs.
Black THQ Fridge is hinged to open in both directions out of the box because of this will sit slightly outside of the Fridge pod Aperture. The CRE-50 will sit completely flush in the Fridge Pod section.
Fridge Option:
Select Fridge Option Dometic NRX50THQ Alpicool Fridge
Quantity:
