Dellmassive`s Camper Van Adventure
OVANO seat base rear covers.
we see these at Busfest and liked the look of them,
they match our OVANO bed system, and cover the holes in the seat, the drivers base has a battery in, and the passenger base has the EHU stuff - that we dont use anyway.
so the Blanking panels seemed like a good option to tidy up the area.
they can be screwed on from inside the seat base. . .
but i decided to try out Velcro for now. . . these are semi permanent and will come out again,
and with the Velcro its easy to pop then and get to the bits under the seat. . .
View attachment 275874View attachment 275875View attachment 275876
A very productive day. When I put the seat bases in i used a flat bit and sunk 2 5mm magnets in to the panel. Click and forget. Strong as well so no rattle but easy access.
The interior . . . .
well after flip flopping and u turning way to many times.
i think we have a made a decision.
the 120 bed seems to have been phased out.
we made up our bed with storage boxes to simulate the standard 2/4 112 bed width, and well have to make do.
there will always be the rull width bed in the roof anyway if things get too tight.
weve decided to downgrade from the rails system, and upgrade the bed from the RNR to the RIB.
there are many reasons for all the above. but the long and short is the rail system is way more expensive and needs a pro fitter to be done properly.
where as the other options, i can do myself - with some help.
ie
remove kombi 1+1+1 system, seats, brackets, seatbelts, floor etc.- offer for sale on T6F
remove the OVANO - offer for sale on T6F
install one piece floor,
install flatpack kitchen cabinetry,
install fixed RIB bed.
well get prices for fitting as well. - but the first place we spoke to wanted £500 just to remove the kombi stuff!!
so what we looking at?
this slate grey / dark grey panels with Oak worktop and splash back.
soft close, pop out buttons,
high level lockers
and the Boss wants the pull-out draws under the bed.
as we both decided we didnt want to do cooking inside,
but water and sink WAS required,
a lot of these builds come with the Dometic 9222 or whatever it its call, so we thinking about getting that fitted, and either not using the gas hob,
or maybe just hooking up a C500 can as at temp?
we are also very interested in the Microwave thing, as well as out small kettle and CTIZ coffee machine.
i think well just have to get it fitted. . . then just find out where to put stuff.
theese guys also off the floor as well, 9mm or 12mm etc.
as for the bed. . .
it seems that the RIB Altair 112 is best suited for us.
so we might be able to get the floor, bed, and kitchen for 4-6K.
now we need to get some prices together,
and one place is in Thetford, only 2hrs away from us. for an eyeball.
the other big deal is . . . poptop or interior first?
we know we would like the VANMAX poptop.
so was planning on getting that fitted first, and having the interior done next?
thoughts?
EDIT:
we looking at this one. . .
K2 Trim Edge Kitchen & Altair Rib 112 Rock N' Roll Bed Bundle (Fixed)​
from £3,200.00
After a long time coming we are now happy to be able to offer our Kitchen and Rib 112 Bed in a discounted Bundle package. The Rib Bed is a M1 crash tested double seat that upon pulling out makes up a full bed.
Upholstery varies from the Simora and Brick style.
Our Kitchens are pre scribed to the T5/T6.
K1 Is our original Live Ply Exposed edged kitchen , The K2 is a lightweight Ply with knock on trim .
This can be collected from our workshop for no additional cost or we can send out Kitchen and Rib bed out on two pallets for £150.
Optional Extras:
Front & Back Bed Board +£200
Oak Folding Table & Leg kit +£150
Oak Veneered Window panel +£130
Both SWB & LWB Kitchens come with Top Cabinets.
Standard Bed Boards are showcased below in the final set of pictures, we have between this and the the sliding drawer units (Featured in main renders)
Drawer Bed Board units do not have a back panel , please message for more details.
Self Build & Pre Assembly options
Our Self-Build kits come with full instructions and all relevant fixings provided. Timing for assembly is highly subjective depending on your skill level but on average for a fully built kit that is sanded, finished and installed we would recommend a days allocated timing. We would say this requires a good grasp of DIY ability but we are always there to help if you run in any trouble, with us having fully assembled kits in house we can use for reference and send pictures of.
You can add pre assembly to this here.
For a guaranteed hassle-free experience all of our kits are available for pre assembly and can be collected directly from our workshop. We often have many kits built up in our showroom which you can find here .
Pre Assembled Pallet Delivery for Mainland UK is £150. Please contact us for Channel Islands and Scottish Highlands as charges for these will be more.
Please note Satin Black colour option is currently a 6-8 week lead time.
with the extras. . .
they also do a 9mm OAK floor to match - which we like.
9mm Oak Floor - SWB T5 T6​
£195.00
** Please note our roofs & floor kits are strictly collection only **
If Collecting from seaside campers there will be a 1-3 week turnaround for LWB.
Render images showcase the design perfectly, some of pictures showcase overhang on sliding door step, this is no longer the case.
We cannot pack these for your own courier collection, collection in person from our workshop only.
A unique new oak flooring for VW Transporter T5 & T6 in SWB & only available at Van Furniture
Real oak veneered 9mm floor, supplied in 2 large pieces, CNC cut to size for the perfect fit, this is not a cheap plastic veneer.
Our Van Furniture Oak Floor is CNC machined with V Cut lines to give a real wood slat effect but is supplied in sheet form ready to install and cut to size. Floor is supplied in 2 pieces for easy fitting, the joins are hidden in the V grooved lines. Install time of a solid wood floor could take several hours, this T5 T6 oak flooring kit in a solid sheet will take 10 minutes.
Finishing: Our oak floors are supplied sanded in its natural form, these floors work great and look fantastic with a floor oil, this gives the flooring protection and shows off the natural warm biscuit oak colour. Our floors can be stained or painted and colour, this is not a cheap plastic laminate.
Note: this is a real oak veneer so is a natural oak wood grain, each piece is different and unique, each piece and each side is different to the next.
Weight: 17 kilos.
Step: We machine a standard full step, Kombi steps fit best over any ply floor.
Our Floors are made from 9mm Oak Veneered MDF.
other options are the fridge and sink kit. . .
Bundle Deal - Dometic 9722 Hob Sink , Tap ,Water Pump Kit & Fridge​
Sale Price:£750.00 Original Price:£796.50
This is available for free delivery alongside any U-Shape bed or full Kitchen Pallet delivery. On its own is a collection item only.
Dometic 97222 R/H Sink and Two Burner Gas Hob – Campervan Two Burner Gas Hob Combination Unit with Water pump kit & Alpicool Fridge all at a Bundle discount!
Can be used with our Van Furniture SWB U-Shape, One stop shop for all your camper kitchen needs.
Black THQ Fridge is hinged to open in both directions out of the box because of this will sit slightly outside of the Fridge pod Aperture. The CRE-50 will sit completely flush in the Fridge Pod section.
Fridge Option:
Select Fridge Option Dometic NRX50THQ Alpicool Fridge
Quantity:
ie
high level lockers
View attachment 275923View attachment 275924View attachment 275925View attachment 275926
as for the bed. . .
View attachment 275927View attachment 275928View attachment 275929
thoughts?
your 1+1+1 is also worth a pretty penny so could recoup some of the cost of the RIb
great idea. . . ill bear that in mind.
i have a load of neodymium magnets that would work.
can you post a few pics of yours and how/where you fitted them pls.
:mexican wave:
thoughts?
Why wouldn’t you get the roof done first? You can then trim before fitting the kitchen. Apart from anything else you can pop it to make fitting the interior easier
yes, that's the plan - roof first (vanmax), then floor, bed, kitchen after.
was asking opinion's to see if people agree.
I've just been doing the same Kombi to camper but have kept one set of brackets and the seat belt so it stays as a five seater, just removing the single seat when we’re overnighting to give room for the R&R bed
I got my one piece floor from Vanbus on here it is a good quality ply and an excellent fit, he cnc cut round the seat brackets etc for me and I would recommend them
Hurry up please as I would like to follow your kitchen fitting tips etc :)
I remember going back and forth on the rails, debating the trade-off between bed width and storage. Ultimately, I couldn’t justify the extra expense, especially with concerns about the grooves and little toes.
Honestly, since having the RIB installed and fixed, I haven’t once had a real need to move the bed. I’m sure you’ll be absolutely fine without it too.
And I definitely wouldn’t want any less storage, storage is invaluable in a small space!
We had a Very Productive day yesterday . . . . we had the first bit of sun I've seen for what seems like months,
and no rain or work. So i had a rummage through the pile of upgrades that has been amassing since the end of last season.
Kombi seat bracket blanks.
if you know, you know . . . and those floor brackets are very ouchie on your feet and knees when staying out in the van.
they just clip in and save your knees and toes . . . . they work well, but a bit pricey for what they are.
How much were the blanks and where did you pick them up from?
Paul
Can I ask what pattern is on the 1+1+1? Could be interested to change for my 2+1 set up.
12 kombi points.
4x for each chair.
I'll get a pic.....
Pics added.....
20250223_194649.jpg20250223_194654.jpg20250223_194718.jpg20250223_194759.jpg20250223_194709.jpg20250223_194831.jpg20250223_194837.jpg
Where you getting the Vanmax fitted?
Hopefully with them direct...
Just waiting for an email reply.
As the quote I previously had was from 2023..so need it updated.
They Yorkshire, where you had yours done.
We obviously just shamelessly copying your roof setup.
About VanMax​
From in-house design to development we are always striving to improve our roofs were possible we do this by using the latest manufacturing techniques to ensure we keep producing quality products.
Both our VW transporter and transit custom roofs are slimline/low profile giving them an aesthetically pleasing appearance which enhances the overall look of your camper van, we pride ourselves on practicality so all our elevating roofs come with a 2 piece roof and nosecone which dramatically reduces wind noise and assists aerodynamics.
If you are trade and are interested in any of our Poptops roofs, get in touch. We are always looking for new opportunities and fitters throughout the UK.
Check out our social media pages on our Facebook page and Instagram. Give us a follow, a like and a share to keep up with latest news
Millbrook Proving Ground​
Safety Systems - Seat Belt Anchorage​
  • Vanmax
  • ECE R14.07
  • Directive 76/115/EEC
  • VW Transporter T5/T6
  • Pop-top Roof
  • C17712
Get in touch​
Postal address
Vanmax Poptops Ltd
Unit 1 Calder Works
Methley Road
Castleford
West Yorkshire
WF10 1NX
Phone number(01977) 367 002
Email[email protected]
Paul
THQ, and a set of 4 was £24!!!
We would need three sets..
So I decided to get two sets and just do the fronts that were most accessable.
Front Grill Trims. . .
The BUS was built as a Trendline, so it has this grill. (1x silver strip)
and the VAN was built as a Sportline, so has the 3x silver strips.
i bought these of a T6F member, . . . . as spares for the VAN, or maybe fit on the BUS?
The question is - can i fit the extra trims in the Trendline grill and fit them to the BUS?
do they just clip on any grill?
or do i need a different grill?
asking before i go dismantling the front bumper if i dont need to . ?
I seem to remember the caravelle grill (which is I think what you have on the van) is different to the standard grill so at least can’t take the top silver trim. I have a standard grill in the garage so I can take a look but I’m thinking a different grill is needed to take them
Just seen the for sale thread; these definitely won’t fit a t6. Let me know if you still want to see the back end of a standard grill
Hmm... If that's the case then I'll have to sell them on.
