Forget the solar for now. As I said earlier today and Roadtripper is also saying the issue is likely the feed from the LB to the back of the van. If that isn’t working correctly you will get the 2 symptoms you have (no hab and odd solar). Check that cable for continuity using your multimeter. Check connections at both ends and any fuses. Once you have the power working correctly to the back then start reintroducing the solar MPPT first, panels once the MPPT is working.Thank you,
I’ve disconnected panels for now.
I have left all panels in cupboards accessible to try and understand problem.
I have ordered some chunky auto electrical wire to see if I can temporarily wire positive if mppt to LB and see if that is stable. If so I may need to consider routing a permanent cable (thus obviating the need for the cbe spades).
On the problem of hab not receiving power from LB, I will try and replace all fuses one at a time under driver seat and see if that reinstates power.
Does that sound reasonable?
All those piggybacked spade connectors look like a potential source of problems too and I would look to tidy that up once you have solved the issues with a busbar to ensure secure connections in the future.
