Many thanks for all the comments, I'm inclined to go for the Roamer given the price and support (and they've taken time to respond previously in this thread).
I was hoping for a straight swap but reading this, it maybe not that easy?
You reckon this needs replacing as well? I've read some people have used the CBE CB 516 with lithium but not the CBE CB 516 version 3 which has a desulphate mode?
If I do have to replace, any suggestions. TIA
You will need to change the black CBE mains charger as it doesn’t have a lithium profile (unless it’s a different model from the one I’m familiar with). That should be fairly easy as you can tap into the existing cables for it. I’m assuming the installer has also correctly disabled or bypassed the charger relay in the CBE DS300 box when the Sterling was installed? That will either be the R37 resistor snipped (bottom left) or switched off (some versions have a switch) or nothing connected to the B1 positive connector (bottom right).
