Officiallyjeroen
Thanks guy,s that what's super fast next week 7 days off so time do some tinkering on the multi an
Check this post: #66Hello there I have a question off course,
Where do you find ore get the latest and New firmware for t6 and rest .
Well, if left seat seat and bulkhead are removed T17p would be the easy way. I have installed a few wires wires through B-pillar up and then behind roof lining to overhead console.I think I will go to the T17p connector an connect the Overheads panel +12V directly to the second battery. Or would be the T10af the easier solution? Any suggestions?
You run the Webasto from starter battery?Coding set to 5101
I think so - will double-check tomorrow...Is it the normal behavior, that the lights of the buttons of the overhead Panel are always on, when the ignotion is on?
Well, not exactly wrong. However, now Webasto's operation is controlled by van's energy management (based on starter battery's state of charge) although the Webasto is energized from the second battery. Thus having low starter battery would inhibit Webasto starting. On the other hand low second battery wouldn't prevent Webasto to start thus flattening the battery.No, I connected almost everything that’s needed for the parking heater to the second battery. => Thermo Top, T91, overhead panel and the air blower. Only the Climatronic is running from the starter battery. Is the coding wrong?
My proposal is to change coding from 5101 to 5001 - then Webasto would use it's internal lmits based on the state of the second battery.
Yes, always on with ignition on (OEM install). Besides that the lights stay on for a while after turning ignition off, etc.Is it the normal behavior, that the lights of the buttons of the overhead Panel are always on, when the ignotion is on?
Great - thanks for your feedback! Then everything is working properlyYes, always on with ignition on (OEM install). Besides that the lights stay on for a while after turning ignition off, etc.
As you may read here, there are two types of Telestart. The one you quoted looks to me the older version and more likely earlier T5 versions.I plan to buy this kit
do you guys think will it fit? any other else is appreciated.![]()
NEW OEM Webasto Telestart T91R LIN 5Q0963513A kit with VW Remote
rear view camera, rvc, parking sensor, steering wheel, airbag, srs, radar sensor, engine ecu, radar sensor, webasto, telestart, volkswagen, mercedes-benz, audi, bmw, vw, skoda, seat, us versioncarxtras.com
Few adaptations needs to be done if you want to use parking heater to warm up your engine coolant circuit. It is configurable via Parking heater module in VCDS.I want to use the kit just to switch on the webasto thermo top and use to heat heater (not sure how to, heater exchanger or water directly through the heater)
In case the blower turned on by the heater (by overhead panel in my case, the Climatronic controls are INOP. You can't do anything there, including changing the blower speed. Webasto controlled by telestart module and turn on the blower once it reaches the operational state and turn it off once it is remotely turned off.As seen in Rober`s video (thanks) blower starts when the webasto is ready to work, Can you switch off the cabin blower with the A/C climatronic controls? in that case, will it turn off the webasto as well or it will still heating the coolant? have anybody tried this?
If outside temp is -2C - +3C within 30min I have engine Coolant temperature hand just above 60C and interior temperature comfortable enough to get thin ice melted from all windows and seats and all plastic warmed u a little bit.do you know, more or less, what is the temp of the coolant after 30 mins running?
I'm far away from my T6 2019 now, I can check at the end of the week more precisely if you have additional questions.Cheers
Miguel
Yes, it works. However, the newer one is 3Q0963513 (usually also less expensive, especially additional remotes).I plan to buy this kit
I will take a look at the newer ones stated by @mmi too. (Thanks )As you may read here, there are two types of Telestart. The one you quoted looks to me the older version and more likely earlier T5 versions.
Please, check the full check list of telestart upgrade earlier in this tread in order to identify your Webasto version.
I guess you are talking about coding the 5001, arent you?Few adaptations needs to be done if you want to use parking heater to warm up your engine coolant circuit. It is configurable via Parking heater module in VCDS.
Well.. that would be more than enoughIf outside temp is -2C - +3C within 30min I have engine Coolant temperature hand just above 60C and interior temperature comfortable enough to get thin ice melted from all windows and seats and all plastic warmed u a little bit.
