Might be a dumb question, but wheres he best place to get the timer and anyone in the SE that can do that flash and vcds for me.
I have Carista - but I'm assuming that wont cut it.
To answer this question you need to read a bit more here, as there are basically several webasto Aux Heaters that are pre-installed by VAG. And different Telestart modules needed for each. What is your MY?OK I'll have a look on eBay for a Telestart - any particular model I need, I read that some T1R and different codes?
I have 2019 T6, I think someone here had 2017 or 2016, maybe they will give the better advice. The number you mentioned in not the one needed to identify your Webasto module. We usually use VCDS full report to correctly identify the unit HW version. Do you have access to VCDS or any other advanced VAG CAN software to read your configuration?So my Shuttle is a 2017 the type is thermo top evo, 12v, 5.0kw and what looks like a part number of 300.010.014.D
I'm not familiar with Carista, but maybe you can check if you can read Aux Heater HW/SW version through it. I see some discussions about it with brief google search.Only Carista so far unfortunately...
5Q0 963 513 AOK I'll have a look on eBay for a Telestart - any particular model I need, I read that some T1R and different codes?
CorrectSo this one should do the trick - then its just VCDS/Flash and I'm done?
NEW OEM Webasto Telestart T91R LIN 5Q0963513A / 5Q0 963 513 A kit with VW Remote | eBay
In Carista use function "Detailed ECU Information" to grab information about Webasto identifiers - probably "Auxiliary heater"Only Carista so far unfortunately...
Yes but you also must flash your aux. heater with "new" firmware(VCP or ODIS).
Can you post your complete unedited VCDS Autoscan?Hi,
i´ve vcp, odis s and e and vcds.
Today i flash my aux. heater from Version 7E0 963 273 A to 7E0 963 272 B. In the database from VW i found also a version 7E0 963 272 C.
Do you have any idea, what the different is?
Next question is, how you flash with vcp? I try it a few times and it didn´t want to work. The flash process stoped with errors and canceld.
With odis e it works well.
My car is MY19 with air aux. heater and a overhead panel and remote control. The part number from the overhead panel is 7E5 919 037 H. I can start my air heater there.
My first thing to do is, add the telestart t91r with the new remote control for water aux. heater. I think, thats the easyest thing.
The second thing is, add a second overhead panel to control the water aux. heater. Do you think it´s possible?
Both panel use can low and high for connection. How know each panel, which heater should it control?
I Saw, the most air heater use a overhead panel with index A-H. Water heater use mostly index J, is that correct?
With VCDS is can´t configure my overhead Panel to control the water aux. heater. Always the air heater (Eberspächer) work with it.
Sorry for my bad english ;-)
Hope you can help me.
Kind regards,
Tom
Sonntag,10,Januar,2021,19:18:05:43807
VCDS -- Windows-basierter VAG/VAS-Emulator l‰uft auf Windows 7 x64(Parallels)
VCDS Version MFT 20.4.2.1 HEX-V2 CB: 0.4513.4
Datenstand: 20201124 DS317.0
www.Diagnosetool.de
Fahrzeug-Ident.-Nr.: WV2ZZZ7HZKH082934 KFZ-Kennzeichen:
Kilometerstand: 59950km Reparaturauftrag:
Fahrzeugtyp: 7H-VN75 (7E0)
Scan: 01 02 03 04 08 09 0D 10 13 15 17 18 19 20 22 25 36 3C 47 55
5F 61 69 6D 6E 78 0B
Fahrzeug-Ident.-Nr.: WV2ZZZ7HZKH082934 Kilometerstand: 59950km
01-Motorelektronik -- Status: i.O. 0000
02-Getriebe -- Status: i.O. 0000
03-Bremsenelektronik -- Status: i.O. 0000
04-Lenkwinkelsensor -- Status: i.O. 0000
08-Klima-/Heizungsel. -- Status: i.O. 0000
09-Zentralelektrik -- Status: i.O. 0000
0D-Schiebet¸r links -- Status: i.O. 0000
10-Einparkhilfe 2 -- Status: i.O. 0000
13-Distanzregelung -- Status: i.O. 0000
15-Airbag -- Status: i.O. 0000
17-Schalttafeleinsatz -- Status: i.O. 0000
18-Standheizung -- Status: i.O. 0000
19-Diagnoseinterface -- Status: i.O. 0000
20-Fernlichtassistent -- Status: i.O. 0000
22-Allrad -- Status: i.O. 0000
25-Wegfahrsperre -- Status: i.O. 0000
36-Sitzverst. Fahr. -- Status: i.O. 0000
3C-Spurwechsel -- Status: i.O. 0000
47-Soundsystem -- Status: i.O. 0000
55-Leuchtweitenreg. -- Status: i.O. 0000
5F-Informationselek. I -- Status: i.O. 0000
61-Batterieregelung -- Status: i.O. 0000
69-Anh‰nger -- Status: i.O. 0000
6D-Heckklappe -- Status: i.O. 0000
6E-Anz./Bed. Dach -- Status: i.O. 0000
78-Schiebet¸r rechts -- Status: i.O. 0000
Adresse 01: Motorelektronik (J623-CXEC) Labeldatei: Keine
Teilenummer SW: 04L 906 056 LS HW: 04L 907 445 A
Bauteil: R4 2.0l BTD H03 9777
Revision: 23101001
Codierung: 0025401C436601080000
Betriebsnr.: WSC 00012 790 50316
ASAM Datensatz: EV_ECM20BTD03004L906056LS 004006
ROD: EV_ECM20BTD03004L906056LR.rod
VCID: 094E6DB229B3F3B305C-805D
Kein(e) Fehlercode(s) gefunden.
Readiness: Nicht Verf¸gbar
Adresse 02: Getriebe (J743) Labeldatei: DRV\0BH-927-711.clb
Teilenummer SW: 0BT 300 012 C HW: 0BH 927 711 G
Bauteil: DSG DQ500-7A H11 5304
Revision: 00H11V01
Codierung: 0014
Betriebsnr.: WSC 00000 000 00000
ASAM Datensatz: EV_TCMDQ500021 001001
ROD: EV_TCMDQ500021_001_VW36.rod
VCID: 2F3AE32AF797FD83FB8-807B
Adresse 03: Bremsenelektronik (J104) Labeldatei: DRV\7E0-907-37x-MK100ESC.clb
Teilenummer SW: 7E0 907 379 Q HW: 7E0 907 379 N
Bauteil: ESC H06 0133
Revision: 00000000 Seriennummer: 60079000001020
Codierung: 307E8098656A86800C7E0179A686619378F700
ASAM Datensatz: EV_Brake1ESCCONTIVN75XGP2 011001
ROD: EV_Brake1ESCCONTIVN75XGP2_011.rod
VCID: 40D8B0965A0972FB122-8015
Adresse 04: Lenkwinkelsensor (G085) Labeldatei:* DRV\6R0-959-654.clb
Teilenummer SW: 6R0 959 654 HW: 6R0 959 654
Bauteil: LENKW.SENSOR H07 0070
Seriennummer: 08011913470162
Codierung: 01
ASAM Datensatz: EV_LWSKLOVW25X 005001
ROD: EV_LWSKLOVW25X.rod
VCID: 7EA40E6E607DC40B20E-802B
Adresse 08: Klima-/Heizungsel. (J255) Labeldatei:| DRV\7E5-907-040.clb
Teilenummer SW: 7E0 907 040 AG HW: 7E0 907 040 AG
Bauteil: ClimatronicT5 H04 0614
Revision: 00001K04
Codierung: 0008000103
ASAM Datensatz: EV_ClimatronicT5 A01718
ROD: EV_ClimaAutoT5Basis.rod
VCID: 6888483612F96ABBFA2-803D
Slave 1:
Subsystem 1 - Teilenummer SW: 7E5 907 049 C HW: 7E5 907 049 C
Bauteil: Heckbedienung H11 0303
Seriennummer: BHB-0012101190015216
Adresse 09: Zentralelektrik (J519) Labeldatei:. DRV\7E0-937-BCM-V1.clb
Teilenummer SW: 7E0 937 090 D HW: 7E0 937 090 D
Bauteil: BCM PQ25 Max4 H82 0762
Revision: B9082001 Seriennummer: 8601 017190106
Codierung: 7ADAF93B0A23200301288F406DEB97F4C094738960CD79703304033F0860
Betriebsnr.: WSC 66305 512 174826
VCID: 2C00F426C601869BDEA-8079
Subsystem 1 - Teilenummer: 5K7 955 559 C Labeldatei: DRV\5K7-955-559.CLB
Bauteil: RLS 090119 05 50 0106
Codierung: 0228EE
Subsystem 2 - Teilenummer SW: 7E0 959 801 N HW: 7E0 959 801 N Labeldatei: DRV\7E0-959-80X-V2.CLB
Bauteil: J386__TSG_FT 004 0654
Seriennummer: KU0KU010011990100196
Codierung: 0400A1
Subsystem 3 - Teilenummer SW: 7E0 959 802 R HW: 7E0 959 802 R Labeldatei: DRV\7E0-959-80X-V2.CLB
Bauteil: J387__TSG_BT 005 0654
Seriennummer: KU0KU018011990181298
Codierung: 1400A1
Subsystem 4 - Teilenummer SW: 7E0 959 442 A HW: 7E0 959 442 A Labeldatei: DRV\3C8-959-537.CLB
Bauteil: E221__MFL-DC1 H02 0103
Seriennummer: 39180002502430038504
Codierung: B5FFFF
Adresse 0D: Schiebet¸r links Labeldatei: DRV\7H0-959-243-V2.clb
Teilenummer: 7E0 959 243 D
Bauteil: Schiebetuer-SG 407 0328
Betriebsnr.: WSC 00012 790 00054
VCID: 3038E056E629E27BE22-8065
Adresse 10: Einparkhilfe 2 (J446) Labeldatei:| DRV\7E0-919-475.clb
Teilenummer SW: 7E0 919 475 AA HW: 7N0 919 475
Bauteil: PARKHILFE 8K H06 0212
Revision: -------- Seriennummer: 28231900705719
Codierung: 318909
ASAM Datensatz: EV_VW75XParkAssis8K 001012
ROD: EV_VW75XParkAssis8K_001_VN75.rod
VCID: 71BE25522123AB73ADC-8025
Adresse 13: Distanzregelung (J428) Labeldatei:| DRV\7N0-907-572.clb
Teilenummer SW: 7N0 907 572 C HW: 7E0 907 572
Bauteil: ACC Bosch PQx H03 0211
Seriennummer: 1101190439AC89
Codierung: 00005000FE0779
Betriebsnr.: WSC 01383 790 50316
ASAM Datensatz: EV_ACCBEGVW361 001006
ROD: EV_ACCBEGVW361.rod
VCID: 3634D64E08CDCC4BB8E-8063
Adresse 15: Airbag (J234) Labeldatei:| DRV\5K0-959-655.clb
Teilenummer SW: 7E0 959 655 K HW: 7E0 959 655 K
Bauteil: VW10Airbag01R 010 0018
Revision: -------- Seriennummer: 003EM002DLYN
Codierung: 000000000000000000000000000000003152
ASAM Datensatz: EV_AirbaVW10BPAVW12X 001028
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 3E24CE6E20FD040B60E-806B
Crashsensor f¸r Seitenairbag Fahrerseite:
Seriennummer: 3495ZRB404V5FGCKI88K
Crashsensor f¸r Seitenairbag Beifahrerseite:
Seriennummer: 3505ZRB405B5DCRU5ORY
Adresse 17: Schalttafeleinsatz (J285) Labeldatei:| DRV\5K0-920-xxx-17.clb-SRI1
Teilenummer SW: 7E0 920 882 A HW: 7E0 920 882 A
Bauteil: KOMBI H02 2030
Seriennummer: 00000000000000
Codierung: 140F030400
ASAM Datensatz: EV_Kombi_UDS_VDD_RM09 A05736
ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
VCID: 2A0CF23ECC7598AB2C6-807F
Adresse 18: Standheizung (J364) Labeldatei:| DRV\7E0-963-27X-18.clb
Teilenummer SW: 7E0 963 272 B HW: 7E0 963 273 A
Bauteil: STH-T5GP2 003 0009
Codierung: 4101
ASAM Datensatz: EV_AuxilParkiHeateWOST5G2 001013
ROD: EV_AuxilParkiHeateWOST5G2.rod
VCID: 2B02F73AC38F81A3D70-807F
Adresse 19: Diagnoseinterface (J533) Labeldatei:. DRV\7E0-909-901.clb
Teilenummer SW: 7E0 909 901 HW: 7E0 937 090 D
Bauteil: GW-K-CAN TP20 H82 0762
Revision: B9082001
Codierung: 042207
VCID: 6888483612796ABBFA2-803D
Adresse 20: Fernlichtassistent (J844) Labeldatei:| DRV\8S0-857-511.clb
Teilenummer SW: 7E0 857 511 F HW: 7E0 857 511 C
Bauteil: FLA H10 0003
Revision: AA001001
Codierung: 040400E200000000000000
ASAM Datensatz: EV_HighBeamAssisAU316 001004
ROD: EV_HighBeamAssisAU316.rod
VCID: 2D06F922FD9B8F93C94-8079
Adresse 22: Allrad (J492) Labeldatei:* DRV\0CQ-907-554.clb
Teilenummer SW: 0AY 907 554 L HW: 0CQ 525 130 A
Bauteil: Haldex4Motion H53 7620
Seriennummer: HA1-00006.11.18
Codierung: 0501
ASAM Datensatz: EV_AllWheelContrHA1VW37X 002015
ROD: EV_AllWheelContrHA1VW37X_002.rod
VCID: 54F08CC6BE71FE5BA6A-8001
Adresse 25: Wegfahrsperre (J334) Labeldatei:| DRV\5K0-920-xxx-25.clb
Teilenummer SW: 5K0 953 234 HW: 5K0 953 234
Bauteil: IMMO H02 2030
Seriennummer:
Codierung: 000002
ASAM Datensatz: EV_Immo_UDS_VDD_RM09 A03710
ROD: EV_Immo_UDS_VDD_RM09_VW31.rod
VCID: 6A8C323E0CF558ABEC6-803F
Adresse 36: Sitzverst. Fahr. (J136) Labeldatei: Keine
Teilenummer SW: 561 959 760 C HW: 561 959 760 C
Bauteil: MEM-FS H04 0183
Revision: AA000000 Seriennummer: 00000358985515
Codierung: 0058130000000000000001210101202020202121202020
VCID: 23121F1AABDF49E36F0-8077
Adresse 3C: Spurwechsel (J769) Labeldatei:| DRV\5Q0-907-566.clb
Teilenummer SW: 7E0 907 566 C HW: 4H0 907 566 F
Bauteil: SWA Master H08 0030
Seriennummer: 0502730845
Codierung: 030311
ASAM Datensatz: EV_LaneChangAssis 001028
ROD: EV_LaneChangAssis_VN75.rod
VCID: 3038E056EAA9E27BE22-8065
Steuerger‰t 2 f¸r Spurwechselassistent:
Subsystem 1 - Teilenummer SW: 7E0 907 568 C HW: 4H0 907 568 F
Bauteil: SWA Slave H08 0030
Seriennummer: 0500395778
Codierung: 030311
Adresse 47: Soundsystem (R184) Labeldatei: 5K0-035-456.clb
Teilenummer SW: 3AA 035 466 B HW: 3AA 035 466 B
Bauteil: KonzernAmp12K H03 6951
Revision: -------- Seriennummer: A1108D00017089
ASAM Datensatz: EV_AudioVerst12KanalSTT3 001001
ROD: EV_AudioVerst12KanalSTT3.rod
Adresse 55: Leuchtweitenreg. (J431) Labeldatei:. DRV\6R0-907-357.clb
Teilenummer SW: 6R0 907 357 C HW: 6R0 907 357 B
Bauteil: AFS-ECU 005 0050
Revision: -------- Seriennummer: --------------
Codierung: 0FCA020001000000
Betriebsnr.: WSC 02748 790 50316
ASAM Datensatz: EV_HeadlRegulVWLWRCC 002006
ROD: EV_HeadlRegulVWLWRCC.rod
VCID: 3A2CC27E3CD5282B5C6-806F
Adresse 5F: Informationselek. I (J794) Labeldatei:| 5G0-035-MIB-STD2.clb
Teilenummer SW: 5C0 035 680 G HW: 5C0 035 680 G
Bauteil: MU-S-ND-ER H41 0475
Seriennummer: VWZAZ2W0719382
Codierung: 06570001AA00000011111106008808031F0100D4002001004F
ASAM Datensatz: EV_MUStd4CTSAT 001022
ROD: EV_MUStd4CTSAT_VW32.rod
VCID: 25160102A56BB7D3014-8071
Datentr‰ger:
Subsystem 1 - Teilenummer SW: 5NA 919 866 AR HW: -----------
Bauteil: ECE AS 20/21 --- 1430
Seriennummer: --------------------
Adresse 61: Batterieregelung (J840) Labeldatei:. DRV\1K0-907-534.clb
Teilenummer SW: 7E0 907 534 HW: 7E0 937 090 D
Bauteil: Batt.regelung H82 0762
Codierung: 330B1A73
Subsystem 1 - Teilenummer SW: 4K0 915 181 A HW: 4K0 915 181 A
Bauteil: J367-BDMConti H03 1050
Seriennummer: 75885202001901150834
Adresse 69: Anh‰nger (J345) Labeldatei:. DRV\1K0-907-383-V2.clb
Teilenummer SW: 1K0 907 383 H HW: 1K0 907 383 G
Bauteil: Anhaenger H12 0130
Revision: 3B001001 Seriennummer: 00000504810899
Codierung: 410D000103000000
VCID: 323CEA5EE425D06B946-8067
Adresse 6D: Heckklappe (J605) Labeldatei:| DRV\7N0-959-107.clb
Teilenummer SW: 7E0 959 107 A HW: 7E0 959 107
Bauteil: HDSG-Modul H02 0653
Revision: 31002002 Seriennummer: 016900178
Codierung: 19530D4003
ASAM Datensatz: EV_HDSGVN46T 203001
ROD: EV_HDSGVN46T.rod
VCID: 2C00F426C681869BDEA-8079
Adresse 6E: Anz./Bed. Dach (J702) Labeldatei:. DRV\7E5-919-037-L2.clb
Teilenummer SW: 7E5 919 037 H HW: 7E5 919 037 H
Bauteil: Dachdisplay H18 0200
Revision: 1110013S Seriennummer: 585744
Codierung: 000106
Betriebsnr.: WSC 00012 790 00050
VCID: 3634D64E084DCC4BB8E-8063
Adresse 78: Schiebet¸r rechts Labeldatei: DRV\7H0-959-243-V2.clb
Adresse 0B: Luftzusatzheizung Labeldatei: DRV\7E0-819-006.clb
Teilenummer: 7E0 819 006 M
Bauteil: J604 Standheizung 0401
Revision: L100400A Seriennummer: 00000000000000
Betriebsnr.: WSC 00012 790 00055
VCID: 313EE552ED33EB73EDC-5185
Ende--------(Dauer: 01:51, Batt.-Spannung Start/Ende: 14.7V/14.8V)---------
Samstag,12,Oktober,2019,16:25:23:43807
VCDS Version MFT 19.6.1.0 HEX-V2 CB: 0.4508.4
Datenstand: 20190806 DS308.0
www.Diagnosetool.de
Fahrzeug-Ident.-Nr.: WV2ZZZ7HZKH082934 Kilometerstand: 22010km
03-Bremsenelektronik -- Status: Fehler 0010
08-Klima-/Heizungsel. -- Status: Fehler 0010
5F-Informationselek. I -- Status: Fehler 0010
Bauteil: R4 2.0l BTD H03 6911
Revision: 23101001
ASAM Datensatz: EV_ECM20BTD03004L906056LS 004005
VCID: 094E6DB229B3F3BF9D7-805D
1 Fehler gefunden:
27277 - Spannungsversorgung
P0562 00 [032] - Spannung zu klein
Sporadisch - unbest‰tigt - gepr¸ft seit letzter Lˆschung
Revision: 00H11V01
Codierung: 0014
ROD: EV_TCMDQ500021_VW36.rod
VCID: 2F3AE32AF797FD8F633-807B
VCID: 40D8B0965A0972F78A9-8015
1 Fehler gefunden:
0397 - Reifendruckwarnung
C102D F0 [008] - Druckverlust
Sporadisch - best‰tigt - gepr¸ft seit letzter Lˆschung
Umgebungsbedingungen:
Fehlerstatus: 00000001
Fehlerpriorit‰t: 3
Fehlerh‰ufigkeit: 1
Verlernz‰hler: 94
Kilometerstand: 21741 km
Datum: 2019.10.09
Zeit: 16:17:51
Codierung: 01
VCID: 7EA40E6E607DC407B85-802B
Revision: 00001K04
VCID: 6888483612F96AB7629-803D
Slave 1:
1 Fehler gefunden:
9480753 - Bedienungs- und Anzeigeeinheit f¸r Climatronic hinten
B10AA 31 [008] - kein Signal
Fehlerpriorit‰t: 3
Fehlerh‰ufigkeit: 7
Verlernz‰hler: 88
Kilometerstand: 14932 km
Datum: 2019.08.18
Zeit: 14:24:38
VCID: 2C00F426C6018697461-8079
Codierung: 0228EE
Codierung: 0400A1
Codierung: 1400A1
Codierung: B5FFFF
VCID: 3038E056E629E2777A9-8065
Codierung: 318909
VCID: 71BE25522123AB7F357-8025
ROD: EV_ACCBEGVW361_VW32.rod
VCID: 3634D64E08CDCC47205-8063
ROD: EV_AirbaVW10BPAVN750_VW12.rod
VCID: 3E24CE6E20FD0407F85-806B
ROD: EV_Kombi_UDS_VDD_RM09_005_VW25.rod
VCID: 2A0CF23ECC7598A7B4D-807F
Teilenummer SW: 7E0 963 273 A HW: 7E0 963 273 A
Codierung: 4101
VCID: 2B02F73AC38F81AF4FB-807F
Revision: B9082001
Codierung: 042207
VCID: 6888483612796AB7629-803D
Revision: AA001001
VCID: 2D06F922FD9B8F9F51F-8079
Codierung: 0501
ROD: EV_AllWheelContrHA1VW37X.rod
VCID: 54F08CC6BE71FE573E1-8001
Seriennummer:
Codierung: 000002
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8C323E0CF558A774D-803F
VCID: 23121F1AABDF49EFF7B-8077
Codierung: 030311
VCID: 3038E056EAA9E2777A9-8065
Codierung: 030311
VCID: 3A2CC27E3CD52827C4D-806F
ROD: EV_MUStd4CTSAT_VW36.rod
VCID: 25160102A56BB7DF99F-8071
Datentr‰ger:
Subsystem 1 - Teilenummer SW: 5NA 919 866 AG HW: -----------
Bauteil: ECE AS 2020 --- 1310
1 Fehler gefunden:
6720 - R¸ckfahrkamera
B1102 31 [008] - kein Signal
Fehlerpriorit‰t: 3
Fehlerh‰ufigkeit: 1
Verlernz‰hler: 69
Kilometerstand: 20284 km
Datum: 2019.09.14
Zeit: 02:40:44
Spannung Klemme 30: 13.1 V
Codierung: 330B1A73
VCID: 323CEA5EE425D0670CD-8067
Codierung: 19730D4003
VCID: 2C00F426C6818697461-8079
Codierung: 000106
VCID: 3634D64E084DCC47205-8063
VCID: 313EE552ED33EB7F757-5161
Ende--------(Dauer: 01:52, Batt.-Spannung Start/Ende: 12.1V/12.1V)---------
That's interesting question! The overhead panel on yours has address 6E. Unfortunately also the overhead control panel for water aux./parking heater is living in address 6E. I don't know how to de-conflict that.The second thing is, add a second overhead panel to control the water aux. heater. Do you think it´s possible?
What coding values you tried to configure your overhead panel?With VCDS is can´t configure my overhead Panel to control the water aux. heater. Always the air heater (Eberspächer) work with it.
Not clear if VW has done the overhead unit separation by suffixes - definitely would be confusing way.The index from my panel is H. Look at Site 5 here in my last post, there is the VW partnumber from my stock air heater. There is also my VCDS scans.
I think you´re right. The H is only for air heater and i think you´re right too with the adress conflict in the unit 6E if i use twice.
I have a remote and a overhead panel for aux./parking heater (as no air heater) - and indeed I haven't used the overhead panel much, the remote is very handy.The other question is, do i need it realy? If the remote control works, why i need a head unit for the water aux. heater? For Timer?
For Timer i can use the stock overhead panel from my air heater. But it´s nice to have twice ;-)
