And how it’s the 13,2v going to help you? Re setting the SOC to 100% when there’s 10-15ah still to go?
Re setting prematurely it’s not the solution here. Your solar is weak to fully charge, and is asking for more absorb time.
The shunt detection voltage should match close your charging voltage. I set mine at 14,1v, charger at 14,2v with 2hrs absorb time. Sometimes I get exactly like you, the solar drops into float, but still ah left to put back. I raise the voltage to 14,4v for a couple of days. If that doesn’t clear it, I increase bulk time from 2 to 2.5hrs. Then I revert back to my previous settings.
This scenario happens when cells needs to balance to recover back capacity, and the balance current is small, taking longer to balance.
What you did, you set the shunt parameters to call it 100% to early.
