If the play is excessive it will fail a UK MOT. If it has passed an MOT it’s not excessive.
2.3. Steering play
To check steering play:
- Make sure the road wheels are on the ground and pointing straight ahead.
- Lightly turn the steering wheel left and right as far as possible without moving the road wheels.
- Check the amount of free play at the rim of the steering wheel.
If power steering is fitted, the engine must be running.
Steering wheel free play should not be more than:
- 13mm for rack and pinion steering, or 48mm if there are several joints between the steering wheel and the rack
- 75mm for non-rack and pinion
These limits are for a standard 380mm diameter steering wheel. The limits should be adjusted up or down accordingly with larger or smaller diameter steering wheels.
Play due to wear or maladjustment must not be confused with apparent play due to the construction of the mechanism, such as caused by the deflection of flexible joints or spring compression in external power steering systems.
Defect | Category |
(a) Free play in the steering, measured at the rim of the steering wheel is:
(i) excessive
(ii) excessive to the extent that safe steering is affected |
Major
Dangerous |
