Hi
@Robert,
Thank you for taking the time reading this... I've just run the Carista detailed ECU.
FEW BACKGROUND NOTES BEFORE:
1. As I've mentioned before, I've got an immobiliser installed by professionals and the car was running with no start-stop error.
2. The same day I got the immobiliser installed, I re-connected and powered my dashcam to the OBD. A few days later, I disconnected the dashcam from my OBD and it was working for a few hours. The next day error came back.
3. The error seems to appear only on the dashboard and start-stop not working.
Many thanks & regards,
L
### DETAILED ECU INFO ###
ECU info obtained with Carista 540099 for iOS:
VIN: WV2ZZZ7HZHH******
Engine
Part #: 04L906056AF
Component: R4 2.0l BTD
Software version: 6207
ASAM/ODX identifier: EV_ECM20BTD03004L906056AF
Coding: 0025401C432701080000 (hex)
Fault codes:
25665 Manufacturer-specific code
25670 Manufacturer-specific code
Transmission
Part #: 0BT300012C
Component: DSG DQ500-7A
Software version: 5302
ASAM/ODX identifier: EV_TCMDQ500021
Coding: 0014 (hex)
[No fault codes]
ABS
Part #: 7E0907379P
Component: ESC
Software version: 0133
ASAM/ODX identifier: EV_Brake1ESCCONTIVN75XGP2
Coding: 617EC0986568847E867B0377A6892192790000 (hex)
[No fault codes]
Instrument cluster
Part #: 7E0920970S
Component: KOMBI
Software version: 1107
ASAM/ODX identifier: EV_Kombi_UDS_VDD_RM09
Coding: 730F010300 (hex)
[No fault codes]
Airbags
Part #: 7E0959655H
Component: VW10Airbag01S
Software version: 0018
ASAM/ODX identifier: EV_AirbaVW10BPAVW12X
Coding: 000000000000000000000000000000003153 (hex)
[No fault codes]
Steering angle
Part #: 6R0959654
Component: LENKW.SENSOR
Software version: 0070
ASAM/ODX identifier: EV_LWSKLOVW25X
Coding: 01 (hex)
[No fault codes]
Parking/steering assist
Part #: 7E0919475AA
Component: PARKHILFE 8K
Software version: 0212
ASAM/ODX identifier: EV_VW75XParkAssis8K
Coding: 30810C (hex)
[No fault codes]
Heater & air conditioning
Part #: 7E0907040S
Component: ClimatronicT5
Software version: 0613
ASAM/ODX identifier: EV_ClimatronicT5
Coding: 0000000103 (hex)
[No fault codes]
Central electronics
Part #: 7E0937090B
Component: BCM PQ25 Max4
Software version: 0744
ASAM/ODX identifier: [none]
Coding: B8AC39BA0B63341293284B647CEB9E549D94698960CC6960320400BF0840 (hex)
Fault codes:
00978 Lamp for Low Beam; Left (M29)
(IGNORE THIS - THAT's CAUSED by MY NEW Philips Ultinon PRO9000 HL)
00979 Lamp for Low Beam; Right (M31)
01495 Bulb for High-Beams, Left (M30)
01499 Bulb for High-Beams, Right (M32)
CAN network gateway
Part #: 7E0909901
Component: GW-K-CAN TP20
Coding: 042305 (hex)
[No fault codes]
Immobilizer
Part #: 5K0953234
Component: IMMO
ASAM/ODX identifier: EV_Immo_UDS_VDD_RM09
Coding: 000000 (hex)
[No fault codes]
All-wheel-drive system
Part #: 0AY907554L
Component: Haldex4Motion
Software version: 7620
ASAM/ODX identifier: EV_AllWheelContrHA1VW37X
Coding: 0505 (hex)
[No fault codes]
Auxiliary heater
Part #: 7E0963273A
Component: STH-T5GP2
Software version: 0009
ASAM/ODX identifier: EV_AuxilParkiHeateWOST5G2
Coding: 4101 (hex)
[No fault codes]
Battery regulator
Part #: 7E0907534
Component: Batt.regelung
Coding: 530B1A73 (hex)
[No fault codes]
Infotainment system
Part #: 5K7035200G
Component: MU-S-D-ER
Software version: 0363
ASAM/ODX identifier: EV_MUStd4CTSAT
Coding: 06570000FF00000011111101008808001F0100D60020010003 (hex)
[No fault codes]
Obtained with Carista 540099 for iOS.
