Thanks. Not sure how I test sensor connection, it all looks secure.
DETAILED ECU INFO
ECU info obtained with Carista 502199 for iOS:
VIN: WV2ZZZ7HZHH1*****
Engine
Part #: 04L906056KH
Component: R4 2.0l TDI
Coding: 0025401C437501080000 (hex)
Fault codes:
25796 Manufacturer-specific code
Transmission
Part #: 0BT300046J
Component: DSG DQ500-7F
Coding: 0014 (hex)
[No fault codes]
ABS
Part #: 7E0907379Q
Component: ESC
Coding: 617E40986564848286780278A68321D279F700 (hex)
[No fault codes]
Instrument cluster
Part #: 7E0920970S
Component: KOMBI
Coding: 740F010300 (hex)
[No fault codes]
Airbags
Part #: 7E0959655H
Component: VW10Airbag01S
Coding: 000000000000000000000000000000003153 (hex)
Fault codes:
12850432 Manufacturer-specific code
Steering angle
Part #: 6R0959654
Component: LENKW.SENSOR
Coding: 01 (hex)
[No fault codes]
Parking/steering assist
Part #: 7E0919475AA
Component: PARKHILFE 8K
Coding: 31810C (hex)
[No fault codes]
Heater & air conditioning
Part #: 7E0907040AC
Component: ClimatronicT5
Coding: 0004000103 (hex)
[No fault codes]
Trailer
Part #: 1K0907383H
Component: Anhaenger
Coding: 410D000103000000 (hex)
[No fault codes]
Central electronics
Part #: 7E0937090B
Component: BCM PQ25 Max4
Coding: B8AC393A0B61341293284F646CEB9E740D94698960CC6960320400BF0840 (hex)
[No fault codes]
CAN network gateway
Part #: 7E0909901
Component: GW-K-CAN TP20
Coding: 042305 (hex)
[No fault codes]
Immobilizer
Part #: 5K0953234
Component: IMMO
Coding: 000000 (hex)
Fault codes:
9456128 Engine Control Module (ECM) not authorized
Adaptive cruise control
Part #: 7N0907572C
Component: ACC Bosch PQx
Coding: 00005800FE0779 (hex)
[No fault codes]
Auxiliary heater
Part #: 7E0963273A
Component: STH-T5GP2
Coding: 4101 (hex)
Fault codes:
00035 Tracers outlets in front center on the right of (E303)
Battery regulator
Part #: 7E0907534
Component: Batt.regelung
Coding: 530B1A73 (hex)
Fault codes:
02252 Generator
Infotainment system
Part #: 5K7035200G
Component: MU-S-D-ER
Coding: 06570000FF00000011111101008808001F0100D60020010003 (hex)
Fault codes:
15360256 Manufacturer-specific code
Obtained with Carista 502199 for iOS.
Download app:
Carista OBD2
Facebook:
https://www.facebook.com/caristaapp
