Anyone got an opinion. on the one fault I still have? Are we assuming this would be solved by the correct battery and coding?
No need to apologise any help much appreciated, I'll have a read of the link.Sorry to ad another swerve ball to the mix, just read this document here https://www.ablemail.co.uk/sites/default/files/products/ablemailbatterychargerselectionguide.pdf which mentions a T5 4Motion that has Stop/Start, but NOT Regenerative braking...
I think you need to contact VW and see if they can give you a definitive requirement for the battery for your van. It would seem that you are caught in that no-mans land between EU5/EU6 and everything else.
Thanks mmiView attachment 55281
I can't see how this would go away by changing battery or any related coding. The description suggests the alternator is not communicating with ECU.
I think the following are proof of disconnect (compared with data exctracted from a MY2013 Amarok having the same battery management as yours SW:7H0-907-534 HW:7H0-937-090:
14-2 Dynamic Field Signal - missing real time value
14-3 Exciter current - missing real time value
26-1 Generator current - missing real time value
26-2 Generator current reserve - missing real time value
18-1 Battery voltage - deviates significantly of "commanded" value at 14-1 Generator voltage (spec)
That is 15.0V vs 14.080V - typically the voltage at battery is 0.3..0.1V below the commanded. My guess is that now the alternator outputs just a "safe" voltage.
No, I don't think so unless it has done 200 thousand miles. The communication wire from alternator is presumably a thin, white/yellow, wire - thus a bit vulnerable. I would check that. IMO the first step is to resolve this fault.I'm assuming your guess is the Automator is on it's way out?!? I haven't had (so far) any problems with the battery going flat.
Sounds "good"the negative terminal was only finger tight. Could this have been enough to cause this fault?
I've read the pdf now but I'm struggling to see why it makes a difference to my battery choice unless I'm missing something.Sorry to ad another swerve ball to the mix, just read this document here https://www.ablemail.co.uk/sites/default/files/products/ablemailbatterychargerselectionguide.pdf which mentions a T5 4Motion that has Stop/Start, but NOT Regenerative braking...
Inspite of what has been said since discussing battery adaption I think I will just go with a 019 type and take the risk that associated issues will be solved by the replacement and coding.No, it's a manual entry only.
See my post #9 on page 1
The Moll EFB batteries are the one's that have been giving so many failures.
There are 2 places that data needs to be changed when re-coding a battery, the type of battery is part of the coding seen earlier.
Software Coding: 030B7A73
The 7 is for EFB, It would be a 1 if it was AGM, or a 0 for Wet cell.
I don't know if you changed the coding to a wet cell, 75Ah (Halfords batteries are made by Yuasa, but there's no code for them so who knows what you'd put there) if the van would alter its charging profile to suit, maybe even turning off the start stop charging regime??
