Why did you mention these two coding values?Thanks again @Robert.
Can you shed any light on the differences between 5001 and 5101?
Lastly, if I want to use VCDS can I buy a 'cheap' cable off eBay and use VCDS-Lite for coding this particular function?
5001 and 5101?
Byte 0 (bit 4 activated & bit 5 deactivated)- enables remote control via Telestart
so this means that your original coding 4101 should be changed to 5101.
