What Have You Bought Today?
Bit of a pricey one today, pre-ordered a Poweroad Low Temp lithium battery, then ordered some Lazer lamps for the front grille. This is in addition to the THQ lights with LED lamps fitted yesterday. Steam coming out of my wallet at the moment and plenty yet to come in the near future as I indulge in the biggest spending splurge in the 4 yrs I've had this van.
Dark room.....beer....breath! (Oh, and stay off the computer for a bit, eh?!!)
Charging time should be fine as the OBD charger is 10.5w.
I'll test it next time I get to go on a long drive!
Might be worth getting a bit beefier power supply, I've got a PD circuit board for when I change my wireless charging mat in the central cubby into a Magsafe one. I've got all the bits, just needs to wait for its turn in the queue. I've got the 12 Mini so I can only charge at 12W, but that's a big improvement over the 5W previous iphones have been able to wirelessly charge. If you've got the full size slab then you can get up to 15W if you feed it enough juice.
What’s the PD circuit board that you have, and how do you have your current wireless charing mat wired into the central cubby?
I have a buck/boost power supply currently connected which I can wind up to 20v (though I don't know what Magsafe chargers can pull) then run it through two of these, one of which will feed the Magsafe
The other one will be in the upper glovebox to give a QC3.0/PD USB C plug to feed accessories that are compatible and the other half's Android phone
To add to what @JOG said, turn your router off. For good!!
Were you guys born reading electronics manuals? I got lost when you mentioned QC3 and so on...
Bought the 2 year Warranty extension from VW and agreed a price with a local company to supply/fit a front splitter, angular side bars and -30mm VW lowering springs. I have a feeling this bug to change/improve isn't going to stop. I blame you lot!:D
We all blame each other @Algor. Best way really.
Just picked these up... But I need some help....:rolleyes::rolleyes::rolleyes::rolleyes:
Id like to use VW Logo caps... so I took a chance and got some 6R0071410 60mm wide at the front face and the rear are about 58mm..so will not fit ....what I think I need is 60mm front with 55/56mm back...if that all makes sense....So can anyone HELP with a good number
Thanks @Loz .....
just found this....has anyone used them
ps... they do other sizes if your in the markets for new style caps ;)
Ah yes I do recal this thread I too added my penneth to the thread. Still lost how you got to electronics from suspension etc.
I dropped the idea of air suspension, leaving a big chunk of money already allocated to van spending
