What Have You Bought Today?
My door card rubber inserts arrive today. :thumbsup:
Easy mod but I will have to cut the top drivers side as my air suspension control is fitted there.
Why they don’t fit them as standard is nuts.
My Velle has them. I'll get the part numbers so the price can be compared against VW ones.
Sgs 2.5t low profile jack.
lifts to over 50cm so more than my current car jack 34cm
always worried me just a cheap wicks car jack so got this bad chap.
Not sure looking at it either. Have to see it fitted in person I think.
It’s a bit Marmite like the bonnet covers.
T5 California had bit of an issue with the roof lip which spawned variants of this cover. Not my cup of tea. I’d quite fancy an external front windscreen “sun shade” though!!!
Apple MagSafe charger:
I've recently installed an Apple MagSafe charger, using a OBD power cable, a USB-C to USB-A adapter, and a neat little magnetic phone mount. It was simple to install with the cables hidden behind the trim between the dash and driver's door. I'm also using a CARPLAY2air adapter with the factory fitted VW Discover Media Infotainment system. It's handy to have the phone on charge and in a visible position.
I've recently installed an Apple MagSafe charger, using a OBD power cable, a USB-C to USB-A adapter, and a neat little magnetic phone mount. It was simple to install with the cables hidden behind the trim between the dash and driver's door. I'm also using a CARPLAY2air adapter (had this for about 10 months, works very well) with the factory fitted VW Discover Media Infotainment system. It's handy to have the phone on charge and in a visible position.
Like it
Looks really usefull indeed! And you don't have the cables hanging around alll the time! Charging time is still pretty long, ain't it?
Charging time should be fine as the OBD charger is 10.5w.
I'll test it next time I get to go on a long drive!
