38 miles for me!!!
Think I'll be buying containers lol
Aparently it wont start if you run it out, not sure if it can cause damage if in middle of journey it runs out.
I get mine from Vw 10 litre containers. I use the vw filler tube it connects to the filler and the container it stops filling when tank is full. Takes about two mins to sort out. I thought that if I use their adblue they can't say I did the wrong thing. £13 for 10 litres.Guys,
I have had this light for the adblue come on today. With the minimum and maximum being shown as 1 Gallon, do I simply add the 4.5 Litres and that's it? Is there a possibility of over filling it, or any other things I need to know before I potentially mess this up?
Thanks in advance.
From the parts dep. I use JCT 600. I got the filler genuine vw of eBay from a delearship cheap.Where ? From the parts or assessories in the dealership
@Oldrat as far as I'm aware you'll screw up the emissions control systems, end up with multiple engine faults recorded and probably void the warranty on the engine and emissions system because it will be tracked that you failed to refill the Ad blue. Not a happy prospect.Apols but a newbie numpy Q.
What happens if you dont refill the adblue?
Not had to use additives since the 70's and using 2-stroke in me motorcicles.
Cheers Ratty
It's a pisser @Oldrat (pun intended - if you don't get it, research constituents of Ad blue!)Oh bu66er then
Looks like I'm about to become an adblue slave
Hi All
I filled in twice £13.99 per 10l from amazon. always filling 10l when T6 dispalys message, never overfilled.
