[Guide] Mobile Solar Panels ? . . . - How I Did It -
Hi all
Please help me get this clear in my mind....
Our T6.1 has the CtekD250SE, 100ah standard leisure battery.
If I purchase the Renogy 200w suitcase, do I need it with or without controller? Does the D250SE have its own controller? And does the suitcase literally just crocodile clip to the leisure battery.
I have read this entire thread but honestly just need the info in plain blinkin English lol
Thanks so much in advance
Northern Soul Gal
Hi all
Northern Soul Gal
I have the Renogy 200watt suitcase. The panels have a void between when closed. It comes ready to go. Just plug the crocodile clips on and attach to your battery.
Thankyou for your replies, I can't understand why the Renogy with controller is cheaper than without? So even though I don't need the controller, it's cheaper to get one with....which would you guys go for?
The cetek can only take a panel with an open circuit voltage of 23 volts max so you need to check the spec of any panel you buy with out a controller to check- 200 watts might be too high in which case you would have to buy one with a controller or get a smaller panel
Hi jimc91
Do you find it enough for your fridge when away for say 1 week
I have a portable fridge and usually camp with electric hook and when I haven’t I don’t stay parked up at any one campsite for long so my leisure battery gets regularly charged. I haven’t tested how long my panel on its own would keep my battery charged up with the fridge running- others on here are great at working out power requirements based on power draw
why would you buy the one without? It’s really easy to remove if you don’t want to use it.
The open circuit voltage on the 200W Renogy panel is 21.8V so should be fine with the CTEK if it can handle Voc of 23V.
there is a link for a Renogy discount in my signature below.
The Renogy 200w suitcase kit has a VOC of 21.8v
so as mentioned above it is compatible with the CTEK D250SE
The Renogy Kit comes in two versions . . . one has a solar controller, one comes without.
the versions that comes with the controller can be crock clipped/ hardwired direct to any leisure battery. . .
or
connected to the ctek d250se to use its internal solar controller.
the kit without a solar controller cannot be connected direct to the leisure battery and must be connected vis the D250se
so, i would suggest getting the Renogy 200w kit with controller.
then you can connect to any van/car/battery, and use the d250se or included controller.
example conecting up via the d250se:
example using renogy controller:
I've had one of these portable solar panels for a few years now. It came with a basic PWM controller and just crocodile clips directly to the battery. It served me well before I fixed 200w of solar permanently on the roof. However on really dull days, because it has its own controller it adds a very useful extra100w clipped straight on to the leisure battery.
or
Hi Dellmassive
Thanks so much for this info, Is the d250se an mppt controller? Or am I getting wires crossed (literally)
Hi Dellmassive
YES - the D250se has an internal 20A MPPT solar controller . . .
The 200w suitcase kit comes with a very good 20A PWM controller - the Voyager 20A.
the recommended up grade for the solar controller is the Victron 100/20 smart - 20A
see here for whats the difference -
and here for the battery upgrade to lifepo4 --
and here for battery monitoring ---
and here for everything else --
That's absolutely brilliant @Dellmassive thanks so so much for your help.
Can I ask you one more thing...if I'm on ehu (no solar involved) why is my leisure battery not being kept fully charged, and say the fridge staying on and cold the whole time?
depends on your setup . . .
post a few pics of your setup, kit, battery's etc and well have a look.
if your leisure battery is going flat when on EHU then you most likely do not have a battery charger on it. ( for the starter or leisure battery )
FYI - if you have a sargent EHU box - its just a basic power supply and not a battery charger - a lot of people get caught out with this, they assume it will charge the LB battery . . . but depending on your loads the battery will run flat after a weekend. - and also the starter doesn't get charged, so that will run flat too.
more on chargers -
more on starter charging --
That cetek doesn’t look connected properly- the thin red wire next to the thin black wire should be connected to a circuit in the fuse box that goes live when the ignition is switched on. The thin black wire should go to an earth if your leisure battery is an agm
