Just read the first posts in this topic...Stupid question time - When you mention regen, what do you mean? I’m on my 1st T6. When turning it off, fan runs as others have mentioned.
Thanks.
Thanks.
Cheers buddy.Normal . . . . its keeping the DPF from melting as you shut down during a REGEN.
Diesel particulate filters | what you need to know | RAC Drive
Dfp Regen, Yellow Light & Adblue - Whats It All About? -Only had my T6 150 for a few weeks and only covered around 250 miles. (20k on the clock) Most of my distance is short journeys. Annual mileage is always around 3 -4k as I work away a lot. Not yet had the experience of the Regen light. I did once hear the fan working after I switched her off, I now assume that was something to do with the regen.
My question is, with me only doing generally short distances should I be pro-active and periodically, once a week maybe, put her in Sport mode and drive on a suitable road for 15-20 mins around >2,000 RPMs.
If it is necessary fair enough but as previous threads have said, goes against the norm for me, relaxed driving, wasted fuel, added miles, etc etc.
thank you for replyRegen beingf cut short . . . ?
DPF Regen, Yellow Light & Adblue - Whats It All About? -
DPF Regen, Yellow light & AdBlue - Whats it all about? - The DFP light is becoming a more apparent issue with modern diesel vans, unfortunately, it’s a fact of modern diesel life. what is a DPF? Diesel particulate filters (DPF) are very effective in cutting emissions, trapping even the...www.t6forum.com
Doing longer journeys are a bit of an issue now though, would leaving the engine running if mid cycle when we get home be a solution?If the van needs to do a regen then it will try and do one as soon as engine conditions allow. This state could be achieved on a relatively short run, so it will try then. The burning smell and fan running are signs that a regen has started, but obviously interrupted. I always assume I need to do a longer run soon if that happens.
Pete
Ah ok, presumably because the dpf has to get so hot to regen that is why the fan then runs when you turn off?Probably the DPF doing a regeneration
