Quite possibly but you would have though they would have it hidden away really. I also suspect, that it's not a one size fits all update judging by the amount of different app variations I've seen on the App info.I get the impression from the manual that the OTA is probably for their testers during development and asking for firmware and using USB is the proper way.
I have a V1. My HDMI is at the end of a 30cm cable from the cluster wiring loom, along with a USB port
From what I've seen it only works with some after market stereos.Ah. But it doesn't do anything yet?
I don’t have anything to connect to itAh. But it doesn't do anything yet?
Wunderbra!I have an after market head unit so Bluetooth is not active on my MFD and I've not known it change radio station. I've not had chance to look at VCDS but it is something I need to do because the language setting is incorrect for me now. Not an issue with the dash but my AUX heater is all in German![]()
My HDMI is still in the box...i assumed it was a choice between that and screen cast thing from the phone?I have a V1. My HDMI is at the end of a 30cm cable from the cluster wiring loom, along with a USB port
The other end isn't plugged in though is it.. unless you had a really early board, where the rear HDMI was naff. If so, I have a few spare internal hdmi swap out boards for the casting board that's in there now. It just connects on the same ribbon as you have. Make sure you really want the hdmi first though.Ah. But it doesn't do anything yet?
Hey Fletch! Check out the links in my bio for new firmware and added bonus graphic.. might sort you out..I really need to keep an eye on this thread more.. had no issues with my digital dash other than the mpg for the tank as mentioned seems way out. I do watch mine as gives me some idea when I need to think about filling up.
Then just the gear change indicator gone, but that's nothing I miss of course.
Any idea if the update is vender specific at all? As the FW update didn't work on mine but my firmware is reporting as app: SportHey Fletch! Check out the links in my bio for new firmware and added bonus graphic.. might sort you out..
