That's expensive! That is what you have to pay for small quantities though, I buy them by the 100 or more at 20p or less ( $0.25? ) each.
Digikey is expensive in the UK also.
Thanks mate, will wire one in.10KΩ NTC
Yeah that makes sense, I will be very surprised if there is an issue. I was more thinking that it may be part of the software to run at max for an amount of time on first start up. But will have a chance to test over the next couple of weeks. Picked up a thermistor today so will rig the remote sensor and test it out.It doesn't drop the output immediately, it is a gradual process and can take 5 to 10 minutes. The pump rate slows and the motor slows but it is hard to hear the changes, it is easy to see when hooked up to the diagnosis program on a computer. I have never seen one that doesn't work correctly although a lot of people say that they are not.
Thanks for the tip. I received the pins and installed the remote temp sensor in pins 8 and 9. No results or difference. Djmoyer is correct, there must be an
firmware change on these units as to how they sense temperature, for sure not through pins 8 and 9. W
HiWhen I sell a heater I tell people that the controller isn't a thermostat and that the heaters measure the temperature of the air drawn into the heater. Of course, normally, the heater receives the air to be heated from the lower regions of the vehicle/vessel so it is not going to get warm air for quite a time by which point anyone sitting or standing is sweltering. The best way is to set the rheostat so that the air at the midheight point of the area which is a comfortable setting and use that as the norm, as you have discovered. The multicontrollers lead people into thinking that they are thermostats by having temperatures to set them at which bear no relation to what the human body perceives.
If you want to get it to work with these controllers acting more like a thermostat using the set temperature you do have to add the remote temperature sensor - this overrides the one that is internal to the ecu in the heater.
all is now clear, thank you very much.The temperature of the air entering the heater will be monitored and once it reaches 18 degrees the heat output will be gradually decreased to maintain that temp. Meanwhile, if you are, as normal sleeping above the floor level you will begin to roast as the temp higher up will be a lot higher. So without an external temp sensor mounted at say shoulder height you will need to set the required temp a lot lower. The fan does not stop and start, it is continuous.
I have now received a new Russian STC Air Top 2000 Webasto heater - lo and behold pins 8 & 9 are present and the terminating resistor is in the harness! I wonder what is going on with yours. Someone selling them out of the back door maybe?
