Webasto AT 2000 - Temperature Sensor? How Does It Work (as In Setup With Controller Etc)
Did you remove the fixed resistor that was across the two wires?
If so you have one of the Russian heaters that cannot use an external temp sensor as mentioned earlier - you are out of luck! Should have bought from a reputable source not cousin Vlad.
Thanks for your reply mate, nothing wrong with cousin Vlad, best presidnt of webasto world, the heater works a treat, installed in a RV but being me I like doing extra so made my heating system like the car airconditioning, fresh and recycle air that's why I wanted to use the external temperature sensor so i use fresh air sometimes but as you said it's a bad luck.
Once again i thank you for your time.
